Hi
The bite point on my rev1 mr2 clutch t is very high. I have been reading stuff on this forum and it looks like the MR has a hydraulic clutch.
It is possible to adjust the clutch bite on a hydraulic clutch like you would with a clutch cable.
If it is possible to adjust how is it done? If its not possible does a high bight point mean the clutch is coming to the end of its life?
Any input very much appreciated?
Adam
[Mk2] [NA] clutch adjustments
Re: [Mk2] [NA] clutch adjustments
bit of a squeeze to get to but behind the clutch pedal theres an adjustment screw
This has been mentioned a couple of times on recent posts
Assuming that the pedal height is correct (this is set at the factory and will never change)
And assuming the amount of free-play on the pedal is within spec (again - this is set at manufacture and is unlikely to change).
There is NO means of adjusting the clutch - The biting point cannot be 'altered' by any adjustment.
SEE:
http://www.mr2-tech.com/bgb/mechanical/ ... clutch.htm
SEE:
thanks very much for this.
regards
Adam
regards
Adam
