[Mk2] [Turbo] intake manifold
black gts
Post by black gts »
hello every one
just a quicky ,iv been looking through the net and no joy so here go's........
has a rev 3 turbo have some form of heater in the inlet manifold, water or electric?
reason is that my temp sensor starts going up even though car not running ](*,)
toxo
Re: [Mk2] [Turbo] intake manifold
Post by toxo »
Throttle body has engine coolant running through it to stop throttle freeze on cold startups. That's there to warm it up... wouldn't be warm until the rest of the coolant system is. Nowt else in the inlet manifold though.
black gts
Post by black gts »
cheers toxo
do you think its worth disconecting it to bring intake temp down as im a tad high with the 205 cc imo
and again cheers :thumleft:
toxo
Post by toxo »
People are a bit 50/50 on that. It's there for a good reason, but the people who do disconnect it have never had any problems...
black gts
Post by black gts »
consider it off then . ill reconect if it gets to about 4c but the car never gets driven straight away from cold
ps been looking diagram /drawing of it , any pointers mate
ant@sbits
Post by ant@sbits »
hiya mate sounds to me that the air temp sensor could be faulty if ur getting high intake temps
toxo
Post by toxo »
2 pipes that go around under the distributor and round the back of the engine hook, then run along the head into the bottom of the throttle body. You can just link them together.
Pretty much slap bang in the middle of this diagram:
16267 IIRC.
black gts
Post by black gts »
got a wheel bearing/2 wish bones and a drive shaft on a french shi7 bucket in the morning, mr2 time all afternoon i hope unless some thing else comes in
i WILL get temps down :sick:
cheers toxo
BLZ-8027
Post by BLZ-8027 »
black gts wrote:hello every one
If the cars not running and the gauge is rising ,doesnt that point to a faulty electrical connection in the gauge ?
mr2ninja
Post by mr2ninja »
black gts wrote:consider it off then . ill reconect if it gets to about 4c but the car never gets driven straight away from cold
I'm also interested in the outcome of dissconnecting the 2 coolant hoses to the throttle body, please update your thread, I want to know if you run into any problems :thumleft: !
jimGTS
Post by jimGTS »
ive disconnected (looped round) those lines
makes taking the TB off alot easier not having to worry about spilling coolent everytime you want to remove the TB completely also.
no problems i can report.
mr2ninja
Post by mr2ninja »
jimGTS wrote:ive disconnected (looped round) those lines
How long have you had the 2 TB coolant lines looped for bro?
jimGTS
Post by jimGTS »
since april....
black gts
Post by black gts »
well its seems to be going to plan
2 tb pipes looped,that has took about 5c off .i have also made the water inlet to the cc the pipe at the rear of it .
while the tb was off i reset the tipe of my probe so it is in the middle of plem. chamber as i think it was heat soaking #-o (it was only 12mm away from the ally )
now for the figures...... 1st 2nd etc .127c coming out of turbo and 45c inlet manifold temp , out side temp was 14c
i know the inlet temp. not to good but i was a bit of a shock when i noticed the out let temp of the ct20 :shock:
to sum it up the off boost is 23c ish on boost 45c with a recovery time of just under 2 mins
any thoughts on these would be good :thumleft:
