It looks as though i may have a coolant leak in the Engine bay
I can see a few puddles on top of the gearbox as well
Any thoughts on where this could be leaking from? Thanks
I cant seem to upload piccys on here
![Sad :(](./images/smilies/icon_sad.gif)
JJ wrote:Subframe/ canister area, check the hose going down the expansion tank.
What happens if theres pressure being exerted in the coolant system, it'll lift the pressure cap( where you fill it up
) and push the coolant into the expansion tank.
Check to see if its blowing out of the expansion tank.
theres a long hose thats comes from it that leads down to the rear subframe area.
lift that up where its visible.
Top up your coolant..
take your car for a blast and see if its coming from there.
if it is.
then theres issues with the coolant being pressurised
= head gasket
/ cracked block.
BTWW wrote:Mine used to leak from the joint between the 2 halves of the coolant elbow.New o'ring sorted that.
Only a couple of pounds from Mr T.
