I would like to read the data on the daughter board in my mine's ecu.
the data may be crypted but the daughter board is connect with the toyota ecu so
I can connect the rom in a eprom programmer, i'll have data but i must have the mine's software to extract the different map
can i use OpenECU
I give you some links:
http://forums2.freshalloy.com/showthread.php?p=1630738
http://wiki.xtronics.com/index.php/EFI_ECU_FAQ
the must:
http://www.mr2.com/forums/stand-alone-e ... puter.html
what's the right program??? I send a message at luke
