[Mk2] [Generic] gear selector cable bush kit ebay
raptor95GTS
Post by raptor95GTS »
has anybody tried ebay bush kit and did you like it? I've heard the brass replacement kits can fall apart quite quickly
Razor04
Re: [Mk2] [Generic] gear selector cable bush kit ebay
Post by Razor04 »
word of warning on these "upgrades" i found it very difficult to engage first gear with the brass bushes fitted. bought mine from gtschris.
i tried rotating / flipping them allsorts still had to force first gear in.
i ended up re-fitting the stock bushes i took out.
i was thinking of enquiring at toyota main dealer for a price on a new set of stock bushes this i think is the way forward :thumleft:
anyone got a toyota part No?
raptor95GTS
yeah that's the thing this ebay kit isn't brass so I dunno..
toyota parts http://www.toyodiy.com/parts/p_J_1995_T ... 312.5.html
so er
90201-08267 *** STD. PART x 3?
33558-12010 SW20..5F x 1
90386-12022 SW20..5F x 2
90468-14017 *** STD. PART x 2
feck I give up lol that's a lot of individual parts to order
djpkins
Post by djpkins »
or you can buy bearingd that are applicable to kids scooter wheels for peanuts and they seem to work fine...jayzer is occasionally putting them up for sale for £2.50 posted...you just need to put a couple of spacer washers either side of the new bearing to bring the dimensions up to the standard bush...for a nice tight fit.
I have fit a couple of set of these on my car and others, and they seem to work fine.
Ruishy1
Post by Ruishy1 »
whats the inner and outer dimensions of the bush ?
might be able to get some ball bearing ones :D
sjm1984
Post by sjm1984 »
I have a set of brass gear selector bushes from GTS chris
i haven't had any problems with them
going4the1
Post by going4the1 »
They are just generic skateboard bearings. The cheapest off ebay will work just fine. Only one of the rubber bushings wears out (the forward/backward link). Best to leave the other one in (the side to side)
BTW Toyota do not sell the rubber bushings by themselves - They will only supply complete gear cable cables (Very expensive).
llcoolj
Bearings
Post by llcoolj »
I got a 4 sets up for grabs £2.50/set posted :lol:
All you need to get is:-
a. 4 Washers (OD30mm ID i think 5mm but just follow the bearing ID hole size)-Basically Mad guard washers you get on cars will be fine :thumleft:
b. 4 Washers (OD15mm ID i think 5mm but just follow the bearing ID hole size)
C50
Post by C50 »
Razor04 wrote:word of warning on these "upgrades" i found it very difficult to engage first gear with the brass bushes fitted. bought mine from gtschris.
I also have trouble engaging gears since fitting :?
djpkins
Post by djpkins »
7mm holes for the washers ^^^^
Craig_MR2T
Post by Craig_MR2T »
Can someone point me in the direction of some better fitting instructions/pictures for this gtschris brass bush kit? The ones supplied are a bit gash
djpkins
Post by djpkins »
if not on here ...there is a photo walk thru on mr2 owners club site....lol....be aware of the starter motors live cable!!!
Craig_MR2T
tried on the mr2 oc but didnt find much.
Also I didnt get the cloth that was supposed to come with the kit from GTSChris for cleaning the pin etc but im guessing some WD40 and a rag will do the same job?
