Just as I got into the work carpark my fuel light came on in my tubby
The nearest shell garage is probably 5 miles, but I might get stuck in traffic on the way...
I really dont want to put any 95 ron in (saisnbury's is literally round the corner), but wondering if I have a choice!
How many miles would you roughly expect if I drive on idle?
How much petrol once the light comes on?
Re: How much petrol once the light comes on?
Ive managed at least 20miles.
I can make 2 trips to work & back with out running out, total about 9 miles through town centre rush hour traffic.
You should be ok
You should be ok
I'm guessing I've got a bit more in the swirl pot too
Just pray the traffic isn't too bad I guess!
Cheers guys
Cheers guys
put £5 of Ron95 in and drive off boost to Shell and fill up with VPower
God knows how much is in when the light comes on, Ive read about peoples cars running out of fuel even before the light comes on!!
I drove to shell today on red with the light going on and off and the garage was closed!! had to try and get to Tescos but traffic was mad because of road works so found a Esso garage and put £10 of Essos Super Unleaded Ron97 just wasnt worth the risk realy
Cheers guys- made it ok in the end- no traffic thank gawd
And it ain't recommended to drive with a nearly empty tank
I always fill up if I have the opportunity, even if its still half full.
PMSL
thanks for the advice- it wasn't by choice, the Shell garage I normally goto is closed down and I got caught out
- IMOC Moderator
i only put a tenner in at a time, less fuel=lighter car, or lighter rear end, wich means more control and less fuel consumption!!
I'd hazard that you have at least 5 litres of fuel left, even when the light is on solid during normal driving. I've had the light on solid and still only been able to get 48-49 litres of fuel in when I've filled up.
That's what fuel filters are for. Seriously, having drained and inspected my old Mini's fuel tank after 20 years on the road, there wasn't one bit of crap in there.
Ren0W wrote:And it ain't recommended to drive with a nearly empty tank
- IMOC Moderator
Slarty wrote:I'd hazard that you have at least 5 litres of fuel left, even when the light is on solid during normal driving. I've had the light on solid and still only been able to get 48-49 litres of fuel in when I've filled up.
bingo, unless he's a f11cking diesel mong!!!
in both of mine the light comes on around 40 litres used, so approx 15 litres left in the tank.
i've done 70 motorway miles with the light on, managed to get 54 litres in when i filled up, so i had 1 litre left
steve wrote:in both of mine the light comes on around 40 litres used, so approx 15 litres left in the tank.
The light comes on about 40-42 ltrs used on my rev3 turbo. I think its a 55 ltr tank but dont want to find out the hard way!
Yup as above, its a 55 litre tank, my light comes on constantly on flat level ground when I have around 9 litres left.
sheppy wrote:i only put a tenner in at a time, less fuel=lighter car, or lighter rear end, which means more control and less fuel consumption!!
Except the tanks in the middle of the car between the two seats
TOTB 2010 Rwd top speed, 1/4 and shootout winner.
10.7@142 on R888 street tyres, 10.3@134mph on slicks,
9's on slicks to come, with a clean full throttle pass! Goal of 0-150mph in a 1/4 of a mile....
greeny wrote:sheppy wrote:i only put a tenner in at a time, less fuel=lighter car, or lighter rear end, which means more control and less fuel consumption!!
Managed 45 miles from when the light came on when the car was on the flat - chickened out after that.
It took 49L after i did that so still 6 litres in there somewhere.
HM
