[Mk2] [Generic] which direction should the front top mounts face??
C50
Post by C50 »
the curved side was facing towards the rear direction of my car
but on the other side it was facing towards the front?? :-s
or are they bouth wrong... should they facing out like the suspension cups :-k
JohnnyC
Re: [Mk2] [Generic] which direction should the front top mounts face??
Post by JohnnyC »
Curved part should face the rear on both sides.
C50
Post by C50 »
thanks :thumleft:
i wonder is there a reason for this curved side.. ?! :-k
Poohbear
Post by Poohbear »
If you look carefully the bearing in the mount is offset in relation to the mounting studs...if you get it fitted the wrong way around it changes the CASTER of your suspension. So it is important to get it the right way round.
Bob
I'm Going To Die Young...But When I'm Very Very Old!
C50
Post by C50 »
Cool, i just put a steel rule across the studs of my TRD mount. The bearing is very slightly (about a mm :o ) towards the straight side :thumleft:
