[Mk2] [Turbo] how do you know when your fuel pump has had it
does your fuel pump make strange noises when it's not functioning properly or is it normal , this is after I've turned the engine off for a few mins
Re: [Mk2] [Turbo] how do you know when your fuel pump has had it
Do you mean the car is making a noise after you've turned it off.. or do you mean that after turning the car off and then back on it makes a noise?
after a few minutes it's been turned off , but only sometimes
