nigel_bytes wrote:Its interesting reading threads on here that the low level warning switch next to the fuel level guage is some kind of ball which gets stuck.![]()
After a lot of searching i have found that in fact it is not a ball at all.
Try doing a search for a fuel guage thermistor, You may recognize the illustration here
Moo wrote:I wondered about that too having fitted a new fuel sender a few days ago and not seeing a ball of any kind.Maybe it was the ball method on the earlier revs and was changed on rev3?
My old sender has 3 holes in the top and bottom of the bit that deals with the low fuel light.I assumed that when the level dropped below this bit the fuel would drain out of the bottom holes and then the light comes on.
toxo wrote:It gets stranger!! I decided not to fill my car up today(am off the bottom of the fuel gauge) so that there isn't much fuel in the tank when I come to take the sender out.
I was driving along on fumes and my low fuel light WENT OFF! WTF?! I can't have wired it in the wrong way around as the plug isn't reversible, but it is from a different car so could I have done something that means it's operating in reverse?!
Awilkinson75 wrote:When i fill the car up the fuel gague wont go all the way to the top and also takes an age to move up, how can i fix the gauge so it will go all the was up? also how many miles should i be getting to a full tank? im getting about 220 mile to a tank but im sure my old MR2 was around the 300+ mark, what should it ba and again how do I fix thi problem? Many thanks
Moo wrote:Have you had the needle off the gauge at all?
