Where does vacuum lines connected to? (Pics request)
razmrtwo
Post by razmrtwo »
As u know there are three holes for the vacuum lines on the intake plenum for the 4AGE 16V red top. But my mechanic blocked of all the lines and they were not connected to anything on the engine. Where does the specific hole connected to? Provide me with pics please..
System-G
Re: Where does vacuum lines connected to? (Pics request)
Post by System-G »
Are you talking about the ones on the throttle when the air intake connects or the others that run via the metal pipes for fuel & TVIS?
LimeyMk1
Post by LimeyMk1 »
Hope these shed some light.
razmrtwo
Post by razmrtwo »
System-G, im talking about the ones on the throttle when the air intake connects.
Limeymk1, where does the blue vacuum hose connect to in your fist pic?
LimeyMk1
Post by LimeyMk1 »
razmrtwo wrote:Limeymk1, where does the blue vacuum hose connect to in your fist pic?
It connects to a little Y shaped pipe that's stuck into the inlet tract.
jimi
Post by jimi »
I'm sure that should go to the idle up VSV, like this
LimeyMk1
Post by LimeyMk1 »
Ah yes you're right Jimi. #-o The VSV then connects to the inlet.
Sorry been staring at a V6 for too long. :lol:
razmrtwo
Post by razmrtwo »
Image Replaced With URL For Quote http://myweb.tiscali.co.uk/jimilawson/a ... 062626.jpg
Thanks for the pics Jimi. That is really helpful. I will try to connect the silicone hose to the idle VSV :thumleft:
LoSt GhoSt
Post by LoSt GhoSt »
delete
