Mark Edwards wrote:Depends on the spec(and revision of the 2) of each car.
If you're talking standard then i'd say the MR2 as it has the same power output but weighs less.
I believe the st205 weighs in at around 1450kg, plus the drivetrain losses would make a difference too.
If you're talking modified then obviously it's anyones guess, depending on whats been done.
Sleep-O wrote:tell us then which is it?![]()
