Is this the life in
Chris
jmachling wrote:The pedal rod is adjustable- get it wrong and the clutch will be slipping from day 1 even though the clutch is brand new.
There's a set-up guide in the BGB.
Pedal freeplay should be 5-15mm and pushrod freeplay should be 1-5mm.
I'd have thought maladjustment enough to slip the clutch would be quite noticeable, though.
Either that, or it could be to do with driving style- if you're slipping the clutch a lot at high revs, mismatching revs between gear changes or resting your foot on the clutch, it won't help matters.
Moo wrote:A bit worrying to see this this as I'm soon to be in the market for a new clutch and was looking at RPS.
Still running the original standard clutch at 288 ATW and it's fine so I may stick with that a while longer if it lasts![]()
