MPH speedo
MPH speedo
How easy is it to change the KPH speedo to a MPH one?
Re: MPH speedo
its just a case of changing the clock faces, if it is mechanical then you are likely going to be stuck with 110 mph but if electrical you can change the dials to 180 mph and get a device that changes the signal it receives to allow the 180 mph to be accurate.![](./images/smilies/spacer.gif)
Re: MPH speedo
yeah best way:
KPH
- MPH
(cable driven) 110mph Clock face
KPH
- MPH
(electric) Stef Derner De-limiter.
Awesome piece of kit, and no wiring!
KPH
KPH
Re: MPH speedo
Haven't got the car yet, but is a late model turbo.![](./images/smilies/spacer.gif)
Re: MPH speedo
i've got a cable driven speedo and its fitted with a mechanical delimiter/converter.
got it from thor racing i think, only takes 5mins to fit as well
Re: MPH speedo
RedMR² wrote:yeah best way:
KPH- MPH
KPH- MPH
how does this delimiter work
any chance you can post a link as where to get it, cheers
Re: MPH speedo
mrtee wrote:RedMR² wrote:yeah best way:
KPH- MPH
KPH- MPH
how does this delimiter work?
delimiter removes the 112 mph limiter on imports and converts KPH to MPH.
![Think :-k](./images/smilies/eusa_think.gif)
Re: MPH speedo
RedMR² wrote:mrtee wrote:RedMR² wrote:yeah best way:
KPH- MPH
KPH- MPH
delimiter removes the 112 mph limiter on imports and converts KPH to MPH.I got mine from www.twosrus.co.uk but I can't seem to find it on there now
quick response, cheers, it was the no wiring part that was of interest and how it works,
![Confused :?](./images/smilies/icon_confused.gif)
Re: MPH speedo
It uses a circuit board and is fixed to the back of the speedo unit and uses the same screws to hold the speedo in place to fix the circuit board, hence the name
"clamping delimiter"
![Smile :)](./images/smilies/icon_smile.gif)
