Azz wrote:Why not get a realy bi fridge, and Cryo=freeze the car![]()
dawolf wrote:It's not really necessary to start the engine every week, maybe once or twice a month should be fine.Also topping up the fuel every month seems a bit OTT as just starting the engine will hardly use any.
Remember that oil degrades over time so you may need to change that again in 12-18 months or so.
alan mc wrote:Hi, I've recently taken my Tubby off the road and stored it in my garage with the aim of resurrecting it in 2011 when I retire.
I've decided on doing the following in order to preserve it.
1.
.Start the engine every week and allow to run for 10 minutes to burn off condensation and charge the battery.
2.
.Engage 1st and reverse gears and move backwards and forwards to prevent the clutch sticking.
3.
.Leave the car without the handbrake on to prevent the rear calipers sticking on and operating the brakes when I move the car backwards and forwards to also prevent the front calipers from sticking.
4.
.Rotate the wheels a quarter turn evey week to prevent flat spots-deformity of the tyres.
I have read that you can support each corner of the car with stands and thus keep the wheels off the ground but some suggest that this could damage the suspension as it is just hanging there.
5.
.Top up the fuel every month or so as it gets used up by my starting the engine, this should help to keep the fuel fresh.
6.
.Car is covered with sheets.
I changed
the oil and coolant recently so they should be ok.
I would appreciate any observations on my tactics and any tips as I would like to resurrect my MR2 in the same tip-top condition as it is in now.
JUIC'IN wrote:One more question, you didnt mention wether the car going to be garaged, or exposed to elements??
alan mc wrote:Hi, I've recently taken my Tubby off the road andstored it in my garage
C50 wrote:JUIC'IN wrote:One more question, you didnt mention wether the car going to be garaged, or exposed to elements??
was thinking of doing this too.
only i dont have a garage
I was looking into car covers but they're quite dear
Tiny wrote:A bloke I know who is doing something fairly similar with a MG BGT had issues with the fuel.![]()
He found it was better to just add really small amounts of fuel rather than keep a tank that was slowly going off as it put more deposits/crap into his engine.
I asked God for a bike, but I know God doesn't work that way.So I stole a bike and asked for forgiveness.
