[Mk2] [NA] stereo wiring
pcfc
Post by pcfc »
Help I need the wiring diagram for my toyota stereo model 13706 i don't know what all the colours are , thanks in advance.
RST
Re: [Mk2] [NA] stereo wiring
Post by RST »
Did you get this sorted?
I might be able to help, but you need to fill-in some details:
  • Year of car and revision
    UK / JDM car, NA or Tubby
    Active or non-active system (if you have subs it's one of two active systems)
    What HU are you connecting -in terms of single DIN / Double DIN etc
Allot of the wiring is the same but the info helps.
...I have some wiring diags I can E-Mail to you if you PM me an address. Or there's some links on here to wiring diagrams I think.
pcfc
Post by pcfc »
I did manage to sort this evetually thanks it turned out to be all around powering the amp which had not previously been done,I'm an electrician and this wiring baffled me!!I'm going to get a wiring diagram drawn up for this model and post on-line might help someone.oh and i've got a 96 uk n/a .
couldn't find how to delete the post thats why it was still on
cheers for your time anyway it's good to know the help and info out there.
Turbo_Dude
Post by Turbo_Dude »
Did you put this diagram up anywhere? I've got exactly the same problem. Just need to wire the amp to power up on the ignition, but dunno which wires on the amp are the power ones.
Return to “ICE and Security”
