![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
System-G wrote:
Watching your driving at the sprint, you weren't slow.It was just spinning more than once pretty much every lap that didn't help
More track practice and track tuition will sort this out in no time at all![]()
I agree with mr Brightman though- the 195 width is far from ideal, but will be better than the 539's.
why not try get 888's in your current size? Toyo do sponsor the chamionship entrants you know
crazybrightman wrote:oh arr 5000miles is including alot of road work purely for track use in 1000miles you can kill them depending on power etc.one advantage of the same size tyres is you can front to rear them to last a bit longer wear wise.
as for wet use well on all the track days ive been on or watched nearly every car thats not only gone off but kissed the barriers nicely has had r888's on they just cant shift heavy water out the way.
im guessing its your second car though so getting away with it is more manageable.
mr2mk1chick wrote:
Tom- the LSD will take a bit to get used to but will do wonders for getting the power down
crazybrightman wrote:as for wet use well on all the track days ive been on or watched nearly every car thats not only gone off but kissed the barriers nicely has had r888's on they just cant shift heavy water out the way.
crazybrightman wrote:i may have to give some a try on my own car then![]()
