My clutch slips when i hit full boost espcially when i floor it from low down in the revs.
![Brick wall ](*,)](./images/smilies/eusa_wall.gif)
Anyway the link above looks like what need, does anybody have this on there car if so whats it like to use??
Thanks dan
Caribbean_Blue wrote:Hi Dan,
The clutch should be strong as s**t unless on way out?
Couple of questions is your peddle noisy?? If so clutch slave cylinder can be a culprit? If so I would change sooner rather than later?
How old is clutch? What power you running? Less than 350bhp??
Reece
RyanRs wrote:My friends GT4 has this problem, he has only a STD clutch, but its recently been changed and he is only running a std car with EBC.
it only slips when turned upto 1.1bar
the oem clutch should be plenty good enough for 1.1 bar shouldn't it?
anyways, be interested to know the outcome of your problem,especially if it is a clutch cylinder.may be the solution to my friends gt4.
