hi there - I have a little problem - I bought a set of leads/distributor cap etc.
but the guy sent me the wrong ones ( for rev1 - I have rev2 )
the thing is - would that work on rev2 with rev1 coil ??
another question is :
would the N/A coil fit the turbo engine ??
it will be perfect if I could put the rev1 N/A coil on my rev2 turbo with rev1 leads and distributor
cheers.
hopefully i made it clear.
[Mk2] [Turbo] N/A coil on turbo engine ??
Re: [Mk2] [Turbo] N/A coil on turbo engine ??
Well according to this they are generic for all revision and all models.
http://www.ayrpark.plus.com/epc1/toyota ... _1993.html
Its just the leads and caps that are different.
hmm so I could Use rev1 stuff on rev2 car .........
Try it..........you`ll never know otherwise.
