[Mk2] [Turbo] MR2 Turbo vs Impreza Turbo?!
Tales of driving experiences you have had.
Whats fastest, a stock MR2 Turbo or a stock Impreaa Turbo Wsi?
MR2
16
62%
Impreza
10
38%
Total votes: 26
luthor1
Re: [Mk2] [Turbo] MR2 Turbo vs Impreza Turbo?!
Post by luthor1 »
It's not *all you have to say* because you keep repeating it! Infact, you keep repeating yourself a lot. You've given your opinions on the matter, thankyou very much, now allow the thread to continue and evolve to the next level. You've not (in the opinion of many) proved anything with your statement.
As for others posting nasty posts about you, then perhaps you should look at why?
Again - you are avoiding the question regarding you lying on purpose to inflame this community. If you did do that, can I suggest you retreat for a while and come back with a different attitude and personality? This thread needs to get back on topic now, which to be fair is -vs- scooby's not EVO's and we have digressed enough - thankyou for your EVO input, now we can get back on topic and talk about the Scooby's.
Scotster
Post by Scotster »
Sorry to the original poster, i have been biting and continuing this discussion also.
Still, scooby... depends how much power u/they have and how good both your 60ft times are (mostly yours as the 4wd will take care of thiers mostly).
Scott =op
dellams
Post by dellams »
Dont worry about it, I dont mind discussing evos too as long as it is factual and a fair discussion rather than a slagging match.
I saw my scooby mate today, his is the 2000 WRX STI model, so is it lighter than mine as he claims and how would that fair against me do you thing on the drag strip? :)
Cheers. :thumleft:
Scotster
Post by Scotster »
dellams wrote:Dont worry about it, I dont mind discussing evos too as long as it is factual and a fair discussion rather than a slagging match.
Cheers. :thumleft:
As i said above, there is a LOT to take into consideration. If both cars are healthy and pushing out the same power it will be down to the driver but the scoob will have the edge off the line so you would have your work cut out to get a decent start.
Your car has the potential to beat his, its just a little easier for him than it is for you ;)
His is 1235kg so its a bit lighter. If its standard you will definitely have him with a good start. If its uprated, it all depends on your car and you.
Scott =op
dellams
Post by dellams »
Yeah thats the problem, it has boost computers on board so I think puts out about 250, what would his stock have been?
Hes getting it re-tuned again this week since is going round the nerburg ring in a couple of weeks, I was going to go but my car is costing too much money at the mo so cant afford it now. :(
Probably for the best, I just know ill end up having an accident! But we are going to a track day when he gets back so that will be fun! Ill be getting mine rolling road and tuned before then! :twisted:
dellams
Post by dellams »
Sorry, slightly off topic but if anyone could help...
http://www.imoc.co.uk/forums/viewtopic. ... 197#671197
Cheers. :thumleft:
mikey2
Post by mikey2 »
Hey all, i currently have a 1994 import WRX and 1990 MR2 turbo, both pushing around the same sort of power, about 250, the mr2 is running 1.1 bar and the scoob just under 1 bar. I must say although the scoob is a great drive, you can throw it around with more confidence than the 2, esp in the wet, i have to say the mr2 is quicker, its power band is lower, ie boost comes in a bout 2.5k the scoob is closer to 4.5k. I know the imports have a bigger turbo the td05, while the uk cars have the td04 and do spool about the same. However, i found the MR2 to feel, if not be quicker than the scoob, you get a much bigger kick in the ar$e when you boot it. I know that if you launch a scoob properly from standing then it is silly quick, but its quite hard to do time and again, and the gearboxes do have a habit of giving up while doing it, where as the mr2 doesnt suffer so much in that respect. I reckon, from driving both cars, if you launch absolutely right the scoob will leap infront, but you will catch it quite quickly, if not before 60 defo after, i wasnt major impressed with the 60-100 in the scoob, it wasnt slow by an imagination, but the 2 was faster to 100, and well beyond!!! After driving the mr2 for a few months, i got into the scoob and used it for a few weeks, being used to the mr2 and when its likely to bite i usually take it easy round corners, but on this occasion i went into a corner way too fast, i cr*pped myself, but it did it, and i know full well the mr2 wouldnt have.
This is my OPINION, not fact, i only go on what i have personally experienced with both cars, and i have to say i am torn between the two, the are both great in their own way.
Bottom line though, i think you will get a quicker 0-100 than your mate, and you will spend less getting there!!!
mike
dellams
Post by dellams »
Thanks for your input mike. Yeah that sounds pretty much how I thought it would be. :)
I love the scoob too, I mean I nearly got one before I discovered the 2! :) My mate goes hes years ago before they were as common as they are know, and yes before the forester and estate models came out with grandads driving them!
That was the final thing to put me off not getting a scoob, I then got my 1st N/A 2 and fell in love with it due to look a lot better than a scoob (in my opinion - prefer the sportly look than rally look). Also loved the captains armchair with controls on both sides and was very comforable for a sports car.
I checked out your car mate, interesting colour scheme going on there! ;)
Do you have any problems with your BOV? I was thinking of fitting one to mine but I hear its a 50/50 hit or miss with a rev1 and 2 if it will run correctly.
Also, how much of a gain did the new intercooler make?
Cheers.
mikey2
Post by mikey2 »
tell me about the colour!!! not my choice!! but is gonna be changing!!!! The bov on mine doesnt make any difference as far as i know, but i may just not notice it, cos its always been lke that, Intercooler wise, it did make a difference, before it was done it was running about 0.8 bar, then after was straight upto 1.1, without changing the mbc, its not so much of a power gain now, its what its capable of holding, temp wise, for higher boost. And yes, the scoob is a great car, i really like it, but i love the mr2!!!! i prefer the seats in the scoob, and i like the 4wd, but looks wise the mr2 wins hands down, not even a competition!!!
alias
Post by alias »
Entered in error.
dellams
Post by dellams »
How comes you prefer the scoobs seats? I would have thought the arm chair MR2 ones were more comfortable? :) Loads of leg room too, can practically lie down and drive! ;)
So your intercooler just means you can hold boost for longer and at higher temp? Not really a increase in power?
Cheers.
Wade
Post by Wade »
Well guys ive had two experiences here.
2005 WRX STI with the huge aeroplane spoiler on the back
and a oldskool 311bhp Type R version
Now the 2005 wasnt a problem the guy actually looked imbarrased but the type R after 3rd gear it was quick :(
My MR2 tubby is stock rev3.
Harry
Post by Harry »
:-k
jetro565
Post by jetro565 »
dellams wrote:My mate has an impreza with about 250bhp I think due to boost computers. But I still get the feeling I could beat it in a straight line but he would win on a track due to his 4 wheel drive.
What do ya think?
the mr2 would beat the subaru. ur lower to the ground with the mr2 its more areo dynamic and if the scooby is standered it might be bad on the coners it could be top havey. if he hasint done the springs and dampers he be going ronnd coners on 3 wheels :tongue: ..... 8) go on the MR2 :thumleft:
dellams
Post by dellams »
I always thought a scoob was better on corners even when stock?
Scotster
Post by Scotster »
dellams wrote:I always thought a scoob was better on corners even when stock?
TBH i don't think its better. I think rolling the MR2 would take the Scoob on a corner. The big thing with the Scoob/Evo and any 4wd car is that you can just plant your foot while going round the corner making it a good bit faster exiting. Try doing that in a RWD car ;)
Scott =op
Drifter
Post by Drifter »
well i dusted an impreza 2day, he was trying to be all cocky and come flying past me 2 start off with, then he realized the mr2 is a bit quicker than he expected, over took him round a motorway island think he was gutted when i went pppshhhh past him :twisted: bye bye lol.
Quigonjay
Post by Quigonjay »
was quite impressed with how quick the scooby wrx type ra was at the sprint race today :thumleft:
he beat me :(
dellams
Post by dellams »
Drifter wrote:well i dusted an impreza 2day, he was trying to be all cocky and come flying past me 2 start off with, then he realized the mr2 is a bit quicker than he expected, over took him round a motorway island think he was gutted when i went pppshhhh past him :twisted: bye bye lol.
lol, nice one mate! :thumleft: You running stock too right? Any idea what scoob and year he was?
I got mine rolling road tested but was in the warm so was under powered at about 180 engine, 160 at the wheels. Took it back for a tune up but it was cold so it was 20 bhp more powerful due to the cold anyway! so now is 200 at the engine, 180 at the wheels. pi$$ed me off a bit though since they only slightly adjusted the ignition timing due to everything all ready being find and running to stock!
They said 200 was normal for the age of the car and a lot of the rev1's and 2's they get in are that. Is there no other way of getting my 20 lost ponies back? :(
I have been tempted with a decat, mongoose exhaust and an induction kit for a while, they reckon should give me about another 70ish? Out of these 3, how much more power does each give roughly? Trying to decide which to do 1st...
Anyway, my scooby mate last night was shocked when I said I only lost 20 at the wheels! :) He said he lost like 40% of his power!!! Before he got it turned up he had something like 240 engine, 170 at the wheels meaning I had more than him at the wheels so probably would have had him! :)
Think hes around what I have at the wheels now, boy he loses sooo much power!!!
dellams
Post by dellams »
quigonjay wrote:was quite impressed with how quick the scooby wrx type ra was at the sprint race today :thumleft:
he beat me :(
And you have a rev3 with mods! Whats yours putting out mate? Any idea what the scoob is putting out then? Did it have mods too?
Return to “Driving Experiences”
