Century Motorsport Drag Car Build
pistol pete
Re: Century Motorsport Drag Car Build
Post by pistol pete »
That is so very very cool
Good work
Century Motorsport
Post by Century Motorsport »
Managed to spend a little more time on the car this week.
Got the bonnet back from the fibreglass shop. Just need to spend some time now prepping it for paint. The angle of the vent is perfect. Im very happy.
Then I got the dash back from being flocked, so fitted it into the car
And the seat and dashboard
With the plans for the car always evolving, it became apparent that we were going to run out of inputs on the Link Fury, so Link very kindly swapped the Fury out for their flagship model, the Thunder.
I'm really excited to explore the capabilities of this unit.
and finally, i brought this as i thought i was quite fitting!
Century Motorsport
Quite a good update to bring today.
In preparation for motor bits being ready I had a trip to earls to start gathering unions needed for oil and fuel system
Then I started on the switch panel blanking off bits and making a lip so I can bolt the panel to-
And now this panel has been flocked the same as the dash.
Next up, we made a start on the wiring loom for the car. It's a very big job, and one that I don't have the skills for, so my good friend Benzo is sorting it for me-
Still a long way to go, but making good progress!
Century Motorsport
The engine bits have now all been machined and the bottom end has been built up..
Fitting in the oil squirters was a very tight job. Not much space at all in there
Main caps have been modified for dowels so that the straps are located right. The block has also been doweled
And the straps
All fitted
I had to modify the sump to clear the rod bolts
Sump on
Front plate going on
Dp pistons
Gas rings
With gasket
ashley
Post by ashley »
Just absolutely glorious....I wish I had the funds for an engine build like this... =P~
Century Motorsport
The head is still having work done so I just used a stock head that I have here for mock up purposes
Packaging getting quite tight
First trial of the pulley and belt. Needed to space the plate slightly, as you can see from the belt sag
Some head and cams pics
And finally a little something we are doing for the skunk 2 inlet to fit to the 3s
J-1
Post by J-1 »
Amazing!!!! =P~
This is one serious, beautiful build!
ashley
Post by ashley »
Century Motorsport wrote:
Trying to work out what you're doing here...
Looks like you made a mold for the internal dimensions of the manifold runners, are you then going to use this as a buck to form the actual runners around in CF or something?
Century Motorsport
The first pic is the shape of the intake runner. Ignore the injector bung, that's just popped there for placement. Then the last pic is the inside runner with the wall thickness built onto it. The mould is the outside diameter of the runner and will be used to cast in alloy in a lost wax process.
I did think CF but bonding it to the flanges would be tricky and may not work well with exotic fuels.
The runners are being made right now and I expect to have them in my hand by next week.
Very exciting! It'll be the best inlet manifold on the market for an mr2 no doubt.
ashley
Post by ashley »
Very nice! You'll have to pm me who is doing the casting for you...
Magic Beans
Post by Magic Beans »
Oh my! :o :o
Ben
Post by Ben »
I'm definitely missing something here, so apologies, but shouldn't the HG go all the way down between the cylinders? :-k
I'm loving this build though. Thanks for posting :thumleft: 8)
2001 BMW M5 (Bahnstormer) | 2004 RX8 231 (the Racecat) | 2001 Volvo V70 (Swedish eBay barge)
Previous:
1989 MR2 Mk1b T-bar | 1988 MR2 SC Super Edition
Century Motorsport
The gasket is only sealing the water and the oil ways. It's the rings that are sealing the cylinders, so it's not needed to go between the 2 cylinders like a normal gasket
Ben
Post by Ben »
:idea: Ah, that makes sense. Thanks :thumleft:
Previous:
C35Rob
Post by C35Rob »
outstanding work, love it!
I've been watching quite a few casting videos on youtube recently (just out of interest) so interested to see how the manifold comes out :thumleft:
Century Motorsport
Here's the latest progress on them. I need to finish off the ports and drill the injector bungs, but I think it's a pretty close match!
seb2790
Post by seb2790 »
no water pump?
Century Motorsport
seb2790 wrote:no water pump?
I'm running an electric water pump :)
Century Motorsport
So we got round to getting the rest of the bodywork sprayed this week now that all the modifications have been made to the bonnet and bumpers.
Massive thank you to Allan Stansfield for his efforts in getting this all finished before he moved to Australia!
Return to “Project Cars”
