Martin F wrote:And for talking sake I have the following results since fitting the new intake temp sensor to compare against my new set up...
Cruising around the radtec is aprox 18-22 degrees centigrade above ambient, ie. it is 15 degrees centigrade air temp outside. , the power fc readings would be around 37 degrees with some small bursts of hard acceleration.
If the car is stuck in traffic then the temp can go 35 degrees above ambient which shows the radiator would maybe benefit from a set of fans...
It was 15 degree cent. when I took her for a spin between 6 and 7pm tonight. air temps are now 26 degrees - 28 degrees after a hard pull, so for talking sake it ranges from 11 degrees to 13 degrees above ambient .
I was hoping for better than that but the car drives totally different with the way it puts the power down.
She is more responsive and feels so much more powerful on WOT. I wouldn't be surprised if she was hitting up towards the 440 bhp mark if sitting on a dyno.
The clutch seems to have sorted itself out also, as long as I take it slowly when changing gear.
Temps however are still getting high if sitting in traffic, hit 40 degrees at one point.
I am going to book the car in for a dyno run and tweek of the map and boost if required. I think the intake temps would also benefit from a border style bonnet and a hole cut behind the radiator as this would let the air go through the radiator and straight out.
Not sure how that will affect the look I was wanting from the car but maybe worth a punt....
All in All, very happy with this core, it works great and the 3" pipes and larger core just make everything feel better
