But do you think its possible to do this work with engine in car?
By the way, my dad talked with some engine mechanic and he told that these blocks don't like to be tightened up strongly
GreddyMR2 wrote:Yes, I will order rev3 gasket.I know sump needs to be removed.
By the way, my dad talked with some engine mechanic and he told that these blocks don't like to be tightened up strongly(it was tightened according to ARP).
MR2 Rich wrote:It could be loads of things.Why don't you get the mechanic that built your engine to have a look at it as the work he has done might be linked to your problem?
GreddyMR2 wrote:We have a diagnosis.
Turbo unbolted- looks fine.
Head is off- rings are gone.
Gaps are about 3mm between cylinder and ring.
But there were good gaps when they were fitted so how could they wear so fast?
One more question.Can I buy original metal head gasket when my pistons are 86.5mm?
GreddyMR2 wrote:Today I visited my engine builder.
All is going quite well, I should get the car back next weekend.![]()
He advised me to use a good oil even on brake-in, because the oil I've used now could have caused a bit of damage on bearings..
There were some very small signs on bearings.
Regarding piston- cylinder clearance
- it's about 0.09mm.
The other guy said me recommended gap for wisecos is 0.07mm, so here we have even bigger.
You can see here old ring fitted in a cylinder with about 2.5mm gap.New rings have almost no gap at all.
http://i.imgur.com/RtRk499.jpg
GreddyMR2 wrote:It's not my detonation signs, they were when I bought the pistons.
Can you explain what is blow by?
I didn't notice excesive knocking sound.
