Let me know if you need more cash to cover it and I'll pop it over.
ekona wrote:Possibly something to sort out on the day John, but is there any danger of me having at least 4 runs instead of 3? I only ask as the general consensus from the Zed lads is that you only get a sensible reading from the car after a minimum of 4 runs due to the way the stupid ECU works, so I'd really like to do that if possible.
toxo wrote:Not a problem at all, spectating is still at pretty low numbers.I forgot to advertise this event on the MK1 club
toxo wrote:If you could that would be great
monkeymax wrote:any chance I can have a run with standard ecu and a run with a piggyback ecu to compare the differences?
toxo wrote:monkeymax wrote:any chance I can have a run with standard ecu and a run with a piggyback ecu to compare the differences?
As long as you can do the ECU swap in 5 minutes while the car is strapped to the dyno then that's fine.
Tiamat wrote:When I went to Millway they ran runs with gaps between to allow tuning and changes
toxo wrote:Tiamat wrote:When I went to Millway they ran runs with gaps between to allow tuning and changes
That's more like the service you get when you're doing mapping rather than just power runs.
