It's all in! Huge thanks to Mark and Tom.
Setup is:
4" 3 way speakers in the OEM mounts in the dash
6x9's in the rear parcel shelf that Neil and Mark made from MDF.
(sorry for lack of pics at this point).
The rears are driven by an amp.
I hate to say it but it was a bit dissapointing upon initial testing, though we found a drastic improvement by using the rears as subwoofers which cut out the mid and high range coming from the rear.
This allowed us to hear the fronts and also allowed us to turn the sub up and down in level, so we found a much better balance.
We still have a bit of an issue with the front speakers getting hammered by bass when you turn it up, so Mark is looking at fitting filters to take all the bass out of the fronts, so we can maximise that at the rears which ought to improve things still further.
The Alpine head unit we bought was a huge PITA in terms of not allowing us to set it up how we so wished.
I think in retrospect we probably should have not gone for 6x9's in the rear.
In an ideal world I think it would really need some separate components at the front, so good sized door speakers, some mid range in the dash and some tweeters around the door pillar area.
Then it would probably work well with a big old sub either in the boot or rear shelf driven by the amp.
Speakers that could handle a bit more welly up front would have negated the current issue we have.
That said it does sound pretty good to be fair and with the fronts doing more of the work
(they really are very good for 4" speakers, but 4" speakers do have their limitations) it does provide a pretty crisp sound which is better than I expected.
As Mark said the setup works better for the kind of music he listens to.
My music tends to have a lot of bass, as it's all Indie with strong bass guitars
(think Stone Roses, I wanna be adored, Fools Gold, breaking into heaven etc), so the rears are a little marginal on bass and the fronts get a bit hammered.
Still I think we'll try those filters on the front to see if it allows us to get a bit more bass out of the rears.
