Its ok lads, tyres dont matter, just run it on the rims!
Graeme
Kongaroo wrote:I can understand how it would make you think torque doesn't matter when you list the 2 examples above.The only problem with that is the 2 values you mention are only the peak torque and peak power values.
You cannot guess the car's acceleration with this alone
- you would need the whole torque and power chart
- these would tell you the torque curve and where and for how long a certain level of torque in the RPMs occured, as well as the max RPM for that engine.
Here is a really good webpage which explains it a lot more clearly than some others on the net:
http://www.boostaholic.com/hptq.html
I think it's a really good read![]()
EarL wrote:
Poor examples Andy, for the reasons given above.
And that statement in bold, is definately not correct.![]()
Two cars can make exactly the same peak horsepower, but one may make more torque at a lower given RPM, and will therefore accellerate more quickly to a given speed.
Point in fact:Top Gear did a thing about the Evo 8 FQ400.
It raced a normal family hatch
(Focus I think), and was flayed alive, as the hatch sped away due to it having more low down torque.
When the Evo's big turbo eventually woke up, the FQ shot past the hatch on a wave of.
.you guessed it,
TORQUE!![]()
Now the Evo made 400bhp.![]()
The hatch, probably made something in the region of 150bhp but it was able top pull away.
Explain that one.
EarL.
Andy Champ wrote:Kongaroo wrote:I can understand how it would make you think torque doesn't matter when you list the 2 examples above.The only problem with that is the 2 values you mention are only the peak torque and peak power values.
Great link, thanks for that.![]()
I've a feeling I've seen the one about the waterwheel before.
I'm quite aware that it's the area under the graph that matters, but I haven't any more data available than torque and power peaks.
.you guessed it,
TORQUE!![]()
Explain that one.
EarL.
The EVO vs the hatch?I don't need to explain it, you did.
Well, mostly.
"When The Evo's big turbo woke up"
- how much power was it making before then?
Let me give you guys some more to think about, now I've got your attention.
First:In order to make something accelerate, you have to apply a force.
That's Newton's physics, F=MA.
Or more interestingly the simple transformation A=F/M.
This states that the acceleration is the force divided by the mass.
So a light car, or one able to provide more force
(not torque, nor power) will accelerate faster.
Are you all with me so far?
Second, the way you get force with a wheel driven vehicle is to apply torque to the driving axle(s).![]()
Aha!
I hear you cry, he admits he is wrong.
Not so!
I can vary the torque applied to the back wheels of my'2 in several ways:
I can put the brakes on(silly under the circumstances) slip the clutch
(only useful when first gear isn't low enough) open the throttle
(which will be fully open, if I'm accelerating hard)
- or I can change gear.
You all know, if you think about it, that lower gears give more acceleration.![]()
(At least for a bit).
Pick say 3000 RPM; in first, floor the throttle.
Neck snapping stuff.
In 2nd, fairly brisk.
In top
- stuff all.
That is because the torque has varied
at the wheel
You'll also all know that you can't do 0-60 in 1st- at least not in a
'2, although the FQ in that Top Gear program might.
That's because you run out of revs.
It's those two together- the revs times the torque
- which are the power output of the engine.
It is that ability to put the torque out
at speed
which allows the car to accelerate.
That little hatch might hold the FQ at first, but only because its first gear will be set to run at much lower speeds than the FQ.![]()
That lower gear will result in a similar force at the wheel from the far lower power
(and torque!) output.
Andy
lauren wrote:Its also worth remembering that it takes a massive power differential between cars to make another car look like its going backwards.
Bibbs wrote:Torque is the only thing you feel and the only thing you can measure on a dyno.
BHP is then obtained from this, by using the speed/rpm.
Dyno's measure torque and rpm, and calculate BHP.Then with smoke/mirrors/thin wires and guesswork you get the pointless flywheel bhp.
And the EVO was beaten by the hatch, as off boost the car has so low compression and so much turbo lag the output from the engine was pathetic.
Scotster wrote:It was a fiat something or other and they both went into 6th gear at 30 mile per hour.
Scott=op
Scotster wrote:You will notice though that if you take everything you said and pitch it to the 350bhp MR2 vrs the M6 that what you said initially doesn't quite hold up.Scott=op
Leeroy wrote:Andy champ, so you say torque doesn't matter, then you copy a previous poster's physics equation of hp= rpm x torque/5,252.
It is clear that both influence one another.
Why not admit you were wrong
Andy Champ wrote:.
I do know that what makes the car accelerate is force at the wheels, and this is produced from the enginepower
working with appropriate gearing.
Andy Champ wrote:
I can also know that you cannot get power out of a rotating type engine without torque.![]()
But it isn't the torque that matters, it's the power.
Andy Champ wrote:
Last thought- what's the torque of a jet, or a rocket?
They sure as heck make things accelerate!
Scotster wrote:Ahh now were talking, i'm a mechnical engineer for an aerospace company.
Scotster wrote:Yup makes perfect sense.The potential energy of the car is in the petrol.
The petrol ignites in the car causing kinetic energy in the pistons and the conrods which turn the crank.
The kinetic energy turns into force which is known as Newtons.
The force with which the crank turns is measured over the distance of the crank known as NM and this can be translated into ftlbs which is torque.
The torque turns the flywheel which in turn turns the gearbox which in turn turns the dif which in turn turns the wheel.
There will be a loss of torque from the fly to the wheel etc.
But, the power of the car is the amount of potential energy turning into kinetic energy as every single car will be different.Not just makes and models but little differences in the car.
Thats the reason a cars
"power" is measured in torque and then the BHP is calculated from that.
BHP doesn't have anything to do with the true meaning of the word power though.
I am curious.Some cars have an actual KW power output on the graphs.
That may be the actual power the car generates which would make a difference.
I just said i don't know much about cars
Scott=op
Scotster wrote:I am curious.Some cars have an actual KW power output on the graphs.
