Speaker fitment / Wiring diagrams. please contribute!
T-Bar Turbo
Re: Speaker fitment / Wiring diagrams. please contribute!
Post by T-Bar Turbo »
well i managed to pick a set of INFINITY-Kappa-60-7cs 6 inch for £70 delivered fingers crossed they will just be a straight swap i will post up once they are in
andykipling
Post by andykipling »
I took neil_turbo's Quality write up on speakers and bought some Reference 5010cs for the doors, i was told to fit them i needed a SAK-2912 kit, but these seem far too big. anyone know what i need to buy or waht i need to knock up out of wood? Any ideas? i have a MK2 N/A.
silverhawk160
Post by silverhawk160 »
Link didnt work, edited sorry, I`ll have to work out how to have all the pictures to come up with the text when I copy and paste as I`ve found an excellent bit of info
Leon.
Post by Leon. »
silverhawk160 wrote:Link didnt work, edited sorry, I`ll have to work out how to have all the pictures to come up with the text when I copy and paste as I`ve found an excellent bit of info
As long as the source link of the images is correct, add Image after it. It also needs to have the file extension after it such as ".jpg".
HTH
silverhawk160
Cheers leeroy, Right heres the info I was going on about I hope its of help to someone as its helped me out. Look through all the links through out the page
http://www.stephenmason.com/cars/mr2audio.html
Here another one too
http://www.stephenmason.com/cars/mr2pc9406.html
:thumleft: :thumleft: :thumleft:
Jhiss
Post by Jhiss »
I have found 2 others wiring diagrams. One of them looks like Poohbear's one, but it's more practical because of the colors of the wires.
1993 Radio and player WITH two Woofer speakers :
http://www.mr2.fr/pdf/radiow.pdf
1993 Radio and player WITHOUT Woofer speaker :
http://www.mr2.fr/pdf/radiowo.pdf
Poohbear
Post by Poohbear »
Check your first diagram link...if you stitch them together and look you will see it is for the two subwoofer system see below :)
Bob
I'm Going To Die Young...But When I'm Very Very Old!
Jhiss
Post by Jhiss »
Hi Poohbear,
It's nice you had a better look than mine on this diagram.
Now it should be an easy game to install my two subs.
Thanks a lot :thumleft:
Ps : I have edited my last post to correct it.
davidf1
car door speakers
Post by davidf1 »
why am i finding it difficult to find some replacement kenwood speakers for my mr2 mk2?
davidf1
door speakers
Post by davidf1 »
by the way it`s for the door,not tweeters though.
SonicSW20
Post by SonicSW20 »
Rainbow SLX265 Deluxe's fit with adapters. Unsure on sizes, didnt measure them :lol:
waggy79
cheers for this
Post by waggy79 »
thanks for this thread, i removed the stereo last week to find a big mess of cut wires in my mk1
this info will help.
again big thank you im gonna tackle this in the morning :)
Amebb
hi
Post by Amebb »
hi
is there a diagram for a 3 amp system ???
cheers
'Honest, seriously, this wont hurt a bit ..... there you go........ 5h1t!!! he's dead!!........ Well, you should'nt have touched my Mr2 !!'
Hez
Post by Hez »
JL Audio 6.5inch components (TR650CSI) fit with a 16mm spacer, tweeters screw into the original location exactly like the oem toyota ones.
SonicSW20
Post by SonicSW20 »
DLS R6A's fit with an 18mm MDF spacer if you cut the plastic on the door card (unnoticeable once fitted). R6A's are pretty huge as well!
kirk
Post by kirk »
Hey guys, I'm trying to figure out why my rear speakers are not currently active. I had the dash apart and whoever messed with the loom originally didn't think an ISO adapter would be adequate so the stock loom has been spliced and pieced together with a load of bullet connectors, very lazy work.
What I need to find is which wires on the loom at that head unit control the rears as I'm thinking they were not wired back in. Partly because there is some 6x9s in the storage lids behind the seats which coincidentally don't work either. Then again I also believe the under seat amp is just along for the ride as well.
Little help.
BLZ-8027
Post by BLZ-8027 »
kirk wrote:Hey guys, I'm trying to figure out why my rear speakers are not currently active. I had the dash apart and whoever messed with the loom originally didn't think an ISO adapter would be adequate so the stock loom has been spliced and pieced together with a load of bullet connectors, very lazy work.
Little help.
All depends on the car ,year model, Uk or import
kirk
Post by kirk »
It's a UK 96 Rev3. Didn't come with factory sub. Just the 6 speaker setup.
Hez
Post by Hez »
im not sure on the colours and i cant compare them to mine because im working away from home at the minute but if it comes to it can you just get a length or black and red and run it from your rear speakers to your loom. Just push all the wire under the kick plates
Post by Martin F »
Thanks for the bump on this thread folks, i spent 30 mins searching the net last night for the rear wire + and - , couldn't find anything then this thread just poped up on the main forum page :thumleft:
Return to “ICE and Security”
