BIG UPDATE:
The transporter came on time and picked the car up.
Nearly a tear in my eye as i waved goodbye
and arriving at Rogue
- I recommend this transporter.
Very professional and reliable and a great price.
So the car has been at Rogue since Tuesday.
.and my wallet has taken an absolute hammering! lol
Dont get me wrong, Matt at Rogue has been brilliant.
He has phoned me 4-5 times a day on some occasions detailing what hes found and what it will take to sort it.
Firstly the exhaust manifold
- it was recommended to get all 9 studs time inserted and replaced as they were looking rusty.
As i had saved money stripping it down myself and i didnt want any further problems with this area I told them to go ahead which they did and now I have 9 time inserted studs.
All new studs and nuts.
They also found that the manifold was warped so this was machined down.
Next
- Matt had noticed soot on the turbo support bracket and when investigated found a small hole in the exhaust housing of the turbo.
Now, i seem to remember JimGTS mentioning this when i bought the turbo off him and im sure it had a bolt or something in it to block it.
It worked fine at the time and had a year with no problems
(i think).
However this must have eventually come out so after Matt had checked with his turbo company he uses, i agreed for him to weld it back up.
So the turbo had to be stripped off the downpipe and manifold and rebuilt back up again when repaired.
So turbo was all reinstalled
(replacing a lost gasket on the oil drain
- later found on the drive way at home lol) and the support bracket found to have the wrong bolt in it so was rethreaded.
Then the whole system re-bled which was another issue as the tap had snapped off the front rad at home.
Matt modified this to allow for bleeding.
.and all was good
(or was it?).
.then more problems started appearing.
I had asked Rogue to check the car over for anything else and get an mot put on it so i could get it home and use it for the summer.
The following was found:
Driveshaft seal fail so gearbox leak.
The driveshaft didnt seem to go in as well as the other so i may have damaged this slightly when installing.
Matt replaced the driveshaft seal and was going to use the same new gearbox oil but found it was milky where it had mixed with water.
I had previously jetwashed the gearbox before reinstalling so its more than likely there was some water still in there so new gearbox oil was used.
Play in NSR balljoint.
I had replaced the OSR balljoint a few years back for a previous mot so it was only right to get this done too.
Lower cambelt cover rubbing on crank pulley as not attached
Now i had the engine refreshed and head rebuilt by Predator Performance.
The new oil pump i supplied came from tcbparts and at the time they did not have an original rev2 turbo oil pump so sold me a 5sfe one which i was told was a perfect fit.
However Simon at Predator had phoned me to say it did sit a little proud though it would not leak.
TCBParts and Predator had not seen this problem before.
At the time it was decided that it was to be left as it didnt look like it was going to leak
- and it looks like it doesnt.
However, i need to get this looked at by Simon at Predator.
He did say it was because of the wrong oil pump.
.im not so sure.
I will be looking at this in the future
- however its not a big issue as its only a noise.
Matt did look at putting a bolt in it without removing the crank pulley but found it couldnt be done so the crank pulley will need to come off to do properly.
I will discuss this futher with Predator Performance.
And finally.
Bad oil leak found.
Originally Matt thought this could be from the crank seal which was also replaced by Predator performance.
However when he removed a bracket of some sort the leak stopped.
He could not understand it but we left it as that for the mot.
.strange.
Matt then put it in for an mot as the garage he uses and late last night I emailed to see how it got on.
.IT PASSED!!!
However the bad news is the oil leak has come back and further inspection reveals its the sump sealant/gasket that failed.
Now before i sent the car to Rogue, while i had the car running
(with the blow on exhaust manifold) i found there was a leak myself around the sump area.
Part of the work Predator did for me was to replace the sump which i supplied.
When i checked, all of the sump nuts were actually finger tight only.
I could undo them with my fingers! So i had nipped them up
(not real tight but to the required torque which isnt much) and that actually did stop the leak i found.
Im wondering if the sealant didnt set properly because the sump was loose?
Anyway, i have contacted Simon at Predator Performance and he is happy to redo the sump sealant free of charge under his warranty.
So now i have an issue
Matt has advised not to drive far with the leak.
I am 90 mins away from Rogue.
I am also another 90 mins from home to Predator Performance.
I also have JDMCombe booked for 2nd June.
1.Do i pay Rogue to redo the sump
(he is 90% sure its the sump sealant) which has been quoted
£160 which goes beyond my budget
(im already over by
£40 so
£200 over budget
- the bill is now over four figures)
2.Risk driving it back(take oil with me and also a tow bar just in case and stop and check oil every 20 miles or so) and repair myself for the cost of the sealant?
3.Risk driving it back home and then on to Predator if they can get me in before 2nd June? If i do this then i will need to use a lieu day at work and hang around for it to be done in Southampton.
After spending an extraordinary amount of money i wanted the car ready to be used for summer.
The car has really taken it out of me the last few months.
I have the missus banging on about the amount of money ive spent
(she doesnt even know this latest bill!!!) and ive just paid for her wedding dress and have another
£10k to pay for a wedding i need to find.
What would you do?
