YVS Performance 5SGTE
J-1
Re: 5S - Second engine rebuild required already!!!
Post by J-1 »
Thanks mate.
The car will be coming off the road shortly for the winter so there will be more cleaning because it's not had that level of attention for a long time!
J-1
Post by J-1 »
It's been a while...
I've done one track day this year and the car ran superb as always! 8)
Not had time with the car to get much done but the plan still stands for:
Fully stripped
Carbotech XP10 brake pads
Standard brake discs
Boot mount intercooler
Side Exit exhaust
ECU (Apexi PFC, Link or Motec) with remap
Fit the Walbro 255lph fuel pump (Already bought)
I've changed the steering wheel to a smaller OMP number... Really liking it! No photos unfortunately... :(
However, this turned up at the door yesterday...
What you guys think, keep it black or get it powder-coated a different colour? Colour suggestions?
I've got two Cobra seats to go in as well. Just need to buy 2 harnesses... 8)
J-1
Post by J-1 »
Just bought two Sparco harnesses for £30. Can't complain at that! 8)
The plan is to get the interior stripped out and get the car up to Stainless Creations in Falkirk to get the cage welded in, seats and harnesses fitted.
Any suggestions on the colour of the cage? I'm considering keeping it black. :-k
J-1
Post by J-1 »
Car is away to get the cage, seats and harnesses fitted this week. :mrgreen:
Boot mount and side exit next.
:twisted:
stephano
Post by stephano »
Side exits rule :twisted:
It would be interesting to compare db
loudandproud205
IMOC Organiser
Post by loudandproud205 »
J-1 wrote:
Today I got the car corner weighed. The car weighed in at 1219kg with 1/3 of a tank of fuel and without me in it. 1309kg with me in it! Yes, I will be dieting! :lol:
The guy that done the corner weighing for me told me that 'ideally' I will get the two cross weights equal, or as close to. These weights are based on a car that didn't have the tyre pressures checked prior to weighing and not knowing if the coilovers are equally/unequally adjusted (heights wrong etc). So this has gave me a good starting point... :mrgreen:
Was this a standard car?
What sort of spec was it when you had it weighed?
Got boost?
Kinda!!!
0.3 bar FTL
J-1
Post by J-1 »
stephano wrote:Side exits rule :twisted:
Yeah, mines will be based on yours. Spoke to Bob and he's kept me right! 8)
J-1
Post by J-1 »
Image Replaced With URL For Quote http://i3.photobucket.com/albums/y89/Ja ... CF1098.jpg
Standard trim car basically. Spare wheel/tool bag still in car as well. It was basically a starting point for me.
When I buy my KW V3 coilovers (and have them set up) I'll be taking it back to the same place to have it re-weighed.
stephano
Post by stephano »
good stuff!
do you have an external waste gate?
J-1
Post by J-1 »
stephano wrote:
good stuff!
Nah, no external waste gate.
I think my next move will be an ECU and mapping session. I plan to extract as much power as I can on the standard engine/turbo. :lol:
Then when it goes, it'll get something 'better' 8)
Based on what you've done so far, would you do anything different?
stephano
Post by stephano »
well tbh (others may argue this) but i would stick with the stock ecu for now
im still using stock ecu and injectors.
i guess your running 1-1.2 bar boost? if so then an ecu and re-map will (for the cost) gain you very little
for what a decent ecu and mapping costs you could get a good 2nd hand turbo setup or hybrid turbo then run lower boost at lower temps and gain a little power that way.
J-1
Post by J-1 »
Yeah, most of the time it's 1 bar. Going to put it back up to 1.2bar.
Will keep that in mind. I've got a feeling I'll buy both though.
For example, say I got a TD06. What boost should I run? 0.8-1 bar?
J-1
Post by J-1 »
Glenn_k
Post by Glenn_k »
Removing sound deadening is one hell of a job. I did mine in the winter (-10 C) and the stuff just jumped right out at the tap of a hammer, but still took me a full day. Must have been a right b**** at higher temperatures.
J-1
Post by J-1 »
http://www.imoc.co.uk/forums/viewtopic. ... 26#1426826
Have a read at this and help me with an idea!
J-1
Post by J-1 »
Big update coming soon
stephano
Post by stephano »
:shock: \:D/
J-1
Post by J-1 »
It's taken long enough, but it's nearly there.
8)
J-1
Post by J-1 »
As promised...
Arches rolled for staggered alloys, spacers and wider R888's.
PPCage welded in.
BMIC with custom fan box.
New custom 3" exhaust system with heat shield (pics to follow)
Just bought a GoPro HERO 3 HD camera and mount to catch all the track action. Buying my Carbotech XP10's next week.
Full geometry kit from Wilhelm Raceworks ordered.
Just got the KW V3's to buy and that's it! :-)
danjama
Post by danjama »
This thread has really inspired me to get my clean on tomorrow! Day off, good weather forecast, lots of new music to enjoy, good times! Think it really looks good when the rain tray is clean, so i'll have a crack at that, and then the 'frunk'.
Great thread. Bit sad to see it go the way of a 'track' car though.
