michael wrote:Hedgehog Dodger wrote:need to get mine on the dyno now..
*anticipates list of excuses why car can't make it that day*
YAWN!!!
You will see.
Following on from what JJ said, I'm just wondering if it's to do with the mix of Rev3 head and HG and block.![]()
I'd be extremely suprised if it turns out to be the water pump.Has anyone heard of a water pump failing?
BTW, you've got to get used to using these quote things, matey!
The Rev1/2 heads have a channel around the combustion chambers, right? So if you're fitting a Rev3 head(which has holes, not a channel) onto an earlier block, would you not just make sure that the holes on the HG line up with the holes in the head?
JJ wrote:The Rev1/2 heads have a channel around the combustion chambers, right? So if you're fitting a Rev3 head(which has holes, not a channel) onto an earlier block, would you not just make sure that the holes on the HG line up with the holes in the head?
Theres just something ringing about the way the coolant is delivered through to the head thats different, I will see if I can work it out over the next few days.
Yes, I guess it would be a matter of lining up the holes with the holes in the head, where I'm coming from is( I'll have to confirm this later
) the the water jackets around the cylinders supply the coolant through the HG, but then if you note.
( again confirmation later
- I could me completely wrong
) where it exits through the head is directly above the hole through the HG
Now this hole say for this example is to the left of the cylinder( in the HG
I'm sure the coolant is supposed to travel across the top of the gasket and exit to the right of the head.
thus a circulation flow across the area before exiting the head.
Now if the hole in the HG is directly above the hole in the head( left for examples sake
), do you think this may cause an air pocket
/ hot spot to the right above the HG
/ head where there is no true flow through
Hope your understanding what I'm trying to get across.![]()
poyntesm wrote:Andy,
Now all you need is to get down the strip and fill in your 1/4 mile times..
.Just finished the section and placed it live.
.You could be the one to knock JJ off the top spot.
Link is at the top beside the usergroup icon.
Regards
Esmond
IMOC-UK-Admin
michael wrote:What happened to the previous number 1 time?
"Andy I thought you had a gen 4 caldina 3SGTE head not a rev 3 head?"
stevecordiner wrote:Andy I thought you had a gen 4 caldina 3SGTE head not a rev 3 head?
