greglebon wrote:Yes, no and yes..
I totally removed the black part, undid the nuts and removed the broken stud mounts from their locations.
After drilling the holes in each end, I bolted them to the black section with machine screws: iirc, I had to file them down to around 4mm in length to get them in properly..
.I used nuts on the back, to ensure a decent fix.
They were tiny M2's: I can send you some if you need them, as I'm sure i have some in a bag somewhere, along with the nuts..
Actually, thinking back, I'm sure there was some Araldite used somewhere, too..
.but I cant remember where.
Probably to bond/ seal everything after I'd bolted them on.
(If in doubt.
.over-engineer it.
Thanks will have a go at that soon as i get a chance Greg
Think can get some 2 mill screws/nuts
If not will give you a shout
Peter
