TRD 2000GT wrote:Hi Mark,
Congrats on the power, that certainly throws that theory out the window..
Do you have an adjustable fuel regulator?
TRD 2000GT wrote:Ah right fair enough.![]()
Whats the best way to find out if the pump i have is standard or not??
Andy
ENSMR2 wrote:I remember reading that HKS and TRD head gaskets are one in the same.May explain why there are HKS parts in there.
BenF wrote:ENSMR2 wrote:I remember reading that HKS and TRD head gaskets are one in the same.May explain why there are HKS parts in there.
Enis, I don't know if that's true- over here, when I did my top end rebuild HKS did 1.6mm HGs, TRD did 1.2 and 1.4mm HGs
- I went for the 1.6mm stopper HKS HG on the car which i hear is still working well
ENSMR2 wrote:BenF wrote:ENSMR2 wrote:I remember reading that HKS and TRD head gaskets are one in the same.May explain why there are HKS parts in there.
Well I did say may be.Come to think of it I am pretty sure it was onimoc I read it.
Maybe the old site or hear, unsure.
Shows you shouldn't believe everything you read/hear.I found many examples of this recently
(nothing to do with this).
N
Andy
TRD 2000GT wrote:Definately sounds like she has a standard fuel pump in there then.![]()
It's running 1bar boost at the moment and when put above that it doesn't make a blind bit of difference.![]()
TRD 2000GT wrote:What confuses me is why the map would be setup for 1.1 and 1.2 bar boost if it didn't make any difference.
TRD 2000GT wrote:As for the turbo, will be finding out at the weekend.
jonno wrote:Sounds more like a flow problem to me if power isnt going up with boost.![]()
Either turbine side or intercooler.
Fuelling is usually dead easy to spot since the AFR goes really lean as boost rises, usually at the top end.
jonno wrote:
Wasnt this the car that Trevor said he personally had dyno'd at 504bhp though?
Neil.
TRD 2000GT wrote:Yep was talking about the map on the fc commander.Just seems a little strange that they would map if for 1.1 and 1.2 bar if it didn't make a difference.
The turbo has toyota stamped on it, but going to take off the housing to see whats inside.![]()
(Can't do it til the weekend because it's in a lock up).
TRD 2000GT wrote:But if these where standard then why the hell would they put on a thick headgasket(baring in mind the car has done 30,000miles).
Twin plate clutch, oilcoolers, TRD dif, HKS cams etc a bit over the top.
TRD 2000GT wrote:Which i found out No.8 is a lucky number in Japanese aswell.![]()
TRD 2000GT wrote:Thats what I thought but I was down mission motorsports run by a Japanese couple and the girl was looking at the car and I showed her the VIN number and she said that No.8 is lucky.At which point I said isn't that chinese and she replied it's lucky for both.
