I realised that I have not updated this for a very long time
Lots has happened since my last post in September!
I redid the majority of wiring in the engine bay to tidy it all up, now the majority of wiring runs in the boot.
Many hours were spent with the soldering iron!
Tried to change the tank to filter line from the old rubber pipe for a braided line with AN fittings, Annoyingly the original fitting was seized and rounded off.
so I had to remove the tank!
I Replaced it with an adapter from Radium engineering and now there are AN6 lines to the filter, regulator and to the engine.
I managed to find a great regulator that fits right ontop of the filter therefore removing a line.
a nice and clean install
(will try and get some pics soon)
Huge thanks to Rory for the Berk exhaust.
I think It suits the car very well in black.
I had to have the mid pipe fabricated to suit the 2gr, but it was pretty straight forward.
Soon to be made repackable and will post some pics of that project
Next up was making the seats fit.
I decided to use stock runners and adapt side mounts to fit.
I welded the two together, and then made them look nice.
Finally they were painted satin black.
And in the car
Next up, I decided to make a little injector cover plate.
Took inspiration from the RAT2 cover.
I made a template out of paper, then card, and then transferred it to metal.
and here is the Engine bay after getting that plate and some other parts powder-coated.
I think it looks pretty good!
And after many other small jobs and days of work, it was ready for the MoT.
The first drive was a little nerve-wracking but the car was great and passed with flying colours.
Id expect so since it is all new!
After a drive to the Driftlimits track, it was time for some photos
Pretty much the only thing left outstanding on the car is wider rear wheels.
Since these are 3 piece split rims, I bought wider rear lips
(1 inch wider) to make them 9j.
It will bring the offset down to around 22 which is on the low side.
Im hoping it will fit ok, but it will really finish off the look of the car.
They have been on the way from the USA for the past month, so I really hope they arrive soon so I can get them built and on the car for the memorial.
More soon!
Julian
