They will be going out via the Royal Mail in the next day or 2 on a First class postage
Chris
Pauln wrote:My kit arrived today, many thanks.Unfortunately the instructions were missing, but I thought I'd give it a bash as it looked straightforward.
Unfortunately I didn't have much luck.![]()
At at he risk of sounding dumb, how on earth do you compress the frunk struts enough to line up with the holes so you can bolt them in place.![]()
Off the car with one end on the floor if I really lean on them I can do this, but on the car whichever end I bolt in first, I just don't seem to be able to put enough pressure on them to make them move the inch or two needed.So I guess I'm missing a trick somewhere along the line.
Paul
Chris_9011 wrote:Thanks for the tip, I'll try out turning them around tonight on mine and see if they still fit..
I think the larger section will be too big on diameter
(I think I tried it when designing the final product, but I'll double check to make sure)
