Just my 2p, but when I did my research regarding brakes, I found a few things that might be worth sharing.
Some of this has been regurgitated from other people, but most has been checked out:
1.
There are 2 types of brakes, adhesive and abrasive.
2.
Carbotech pads fall into the adhesive category
2a.
This means that the pads deposit a
'sticky' material onto the disc during bedding in which then forms the adhesive surface for the pads to bind to
2b.
My opinion here, but I can't imagine how grooved or drilled discs would help when using carbotechs
2c.
Carbotech pads
require new discs
, or at least discs which have never been used with an abrasive pad
3.
Brakes are most effective just before they lock up
4.
Brake bias is only important on a road car to ensure that the front brakes lock up before the rears.
How close the gap between front
& rear lock up is up to driver preference, but for safety on the road, this should be a decent gap.
On the track, the gap should be as small as possible.
5.
ABS changes things a bit.
So, if your car is a road car, as long as the bias keeps the fronts locking up before the rears, then you'll be fine.
You aren't likely to be pushing brakes hard enough to need
maximum
braking effectiveness on the road.
If your car is a track car
(like mine), then I'd think less about buying brakes that maintain stock bias, and more about controlling the bias for your driving style.
I'm considering a brake bias controller for mine, but for now, am happy with the Brembo up front, and the stock rev 2 at the rear.
They brake well, and once I fit my wheel sensors to the data logger, I'll be able to monitor brake lock ups to see if front's or rears lock up first, and also what load the car is under when they do lock up.
Data is worth a million forum posts
My 2p
