Noble M500 Upgrades & Overhaul
Re: Noble M500 Upgrades & Overhaul
its all the odd little jobs make a big difference
How's this progressing? Will you be ready in time for the grand tour?
Good weather and long evenings has allowed progress. First job was to repair the other (O/S) lower wishbone mount. This had corroded the same as N/S and was only visible once the wishbone was removed:
Plate cut, shaped, drilled and tack welded.
Plate was then seam welded, and the last part of the chassis stripped of old paint, degreased, and given 3 coats of POR. The paint will be left to fully cure before fitting new wishbone.
Next job was new front floor. I'd laready had a new floor cut, using the old floor as a template. Drilled 102 holes plus a few drain holes, and attached to chassis with 102 stainless rivets:
Now to the PAS cooler. After 10 years it was looking worse for wear, and Noble's method of mounting the cooler was not the most imaginitive:
So, together with new cooler, i bought some custom rubber mounts:
Drilled some holes in the new floor, and after washing out to remove any debris from manufacturing, new cooler fitted:
Excellent progress Pete! Will have a brew/chat/nose round when I come up tomorrow.
Very nice work, as always
Still on track to be ready in 4 1/2 weeks? Or should I be looking at things you can carry in the Honda
That mount your doing a great job it'll be worth it
My TRD WIDEBODY build thread http://www.imoc.co.uk/forums/viewtopic.php?t=164957
Seen this today, looks mint compared to how it was when Pete removed the front clam!
Completed O/S suspension this evening. As per N/S, upright has been crack tested. New wishbones, new primed and painted track rod and track rod end, new poly bushes and upper and lower balljoints. All new nuts, bolts and washers. Ready for torquing up:
Now onto brake lines. Old brake lines and all adaptors etc removed and binned. New Goodridge hose, and all hose ends and adaptors replaced with stainless items. Bonded washers sort out sealing adaptors into calipers.
Instead of tiewrapping the brake lines to the wishbones, had these made instead:
Next is N/S brake line, and bleeding.
Nice touch with the lines mountings It's the little touches which really make the difference.
Nice work Mr.G
Shaping up rather nicely. I seem to remember you wanting to have the engine built and front clam sprayed before Lemans...
How time flies!
How time flies!
RedMR² wrote:Nice work Mr.G
How time flies!
Time certainly does fly! Been waiting 8 weeks for my radiator from Pace. Was told the custom core was made last week, and that rad was being made yesterday.
I know the core was made because................... UPS delivered it to me yesterday afternoon! Aaaagggghhh!
Meanwhile, new all-stainless tyre valves fitted to wheels:
Cars coming on great I love those wheels there so light too
The rad has finally arrived?!
You could finish those wheels off nicely with these
Magic Beans wrote:The rad has finally arrived?!
Ding dong- that's where it's at, right there!
No, not all of it. Just the core.
Hmmm, nice idea, but i think the blue will clash with the gold.
Saw this in person last week . Wow, just wow 600 bhp you were going for weren't you Peter . will be ......... Interesting
jimboi wrote:Saw this in person last week . Wow, just wow 600 bhp you were going for weren't you Peter . will be ......... Interesting
Yep, new engine will be around 560-580bhp. Torque will be limited to 500ftlbs to look after the gearbox.
Peter Gidden - SBITS wrote:orque will be limited to 500ftlbs to look after the gearbox.
Pffft. Is that all?
2001 BMW M5 (Bahnstormer) | 2004 RX8 231 (the Racecat) | 2001 Volvo V70 (Swedish eBay barge)
Previous:
1989 MR2 Mk1b T-bar | 1988 MR2 SC Super Edition
Previous:
I've been in it running at half boost and its a f***ing animal.
Looking forward to a ride out in it when it's done and run in
Cheers Pete.
Cheers Pete.
Well brake lines finished this evening, and annual change of fluid with SRF done.
And after 9 weeks of waiting, UPS delivered an enormous box from Pace Products today.
Custom built 4 core race-spec. radiator. 78mm core, original was 50mm:
Next jobs are to fit heater assembly and wiper motor, and coolant and PAS oil cooler lines...
