just remembered reguarding the conversation earlyer about the adjustable topmounts this is the reply i got from driftworks-
Hi George,
They are fixed but with either increased or decreased camber. We recommend fitting them aligned for more negative camber, this provides better front end grip and overall handling. Of course if your primary concern is tyre wear then you can also run them with less negative camber for flat contact patch.
Cheers, Ben
Broke-SmithSales
ManagerDriftworks Ltd.
phone: +44(0)845 869 2555
fax: +44(0)845 127 4019 www.driftworks.com www.hsdcoilovers.com
hth
i just had another email from driftworks because i was wondering why they hadnt arrived yet and apparantly they didnt have enough in stock to supply the full group buy amount so now i have to wait...
4 WEEKS!
maybe longer
I rang them today actually to find out what was going on. And they had completley sold out of MR2 and MX5 units. So, looks like i'm in for a long wait as well
i'm fitting mine at the moment (not part of the group buy though), I'm using standard sized Drop Links. The drop link mount is adjustable up and down so I'm hoping this is fine.
boyleonthebum wrote:i'm fitting mine at the moment (not part of the group buy though), I'm using standard sized Drop Links. The drop link mount is adjustable up and down so I'm hoping this is fine.
How are these?
I missed the group buy so hope to benifit from somebody elses experience first.
Did you know they are 10kg rear and 6kg front spring rate?
Thats hard!
Any feedback?
