Ok, can people start putting their names down including acceptance of the disclaimer. Hopefully the figures wont have changed for the kits.
Username - KIT TYPE (see above) - Disclaimer Read & Agreed
example: cantfindausername - FULL KIT - Disclaimer Read & Agreed
after reading through the link has anymore thought been put in to other calipers? i run rev1 versions at min, but would prefere to upgrade to something a little more special than rev3 versions should i upgrade.
No would be the answer there. The rev2+ calipers are pretty good. And the difference with the bigger discs is quite something, especially from high speed.
Hi all. Just thought i'd post a pic up of this brake kit installed on my mr2 with 17 inch wheels. I was very impressed with the quality of the machined parts and they fitted perfectly. I've since used the car on track and they held up perfectly. Never once did i loose faith in them braking late for a corner as i experienced no fade whatsoever (This was a problem on my rev 1 setup which had uprated pads and discs) and my talent gave up long before the brakes did. The pic doesn't do them justice as they're much prettier when the discs are clean but my 2 is laid up for the winter.
I'm a bit behind on getting information at the mo as I need to visit the machine shop to see what we can do.
So far there has only really been enough interest in the rear set rather than more of the full set. Which would you be after?
Bagaz - its great to see that you've managed to take them on track. That feedback is brilliant! Thank you!
