Now that the Bomex is fitted, I began building the splitter, as was always
intended.
A lot of thought had gone into how to build this, and what materials
to use etc.
But what helped the most was that Scott who regularly works on
my car, with tricky modifying jobs such as fitting the seats on the ground rails
etc, had literally just finished building a chassis mounted one for his S2K.
So he knew exactly what he wanted to do when it came to building mine,
Plywood
for those that think this is crazy, its actually used on a lot of
Time Attack and track based cars right up to some of the top teams
Its also cheap and easy to source, and would
/ will look great once the full plan
is finished.
The plan was to build two splitters, one out of 10mm
& one out of 5.5mm
ply, the first 10mm will be simply wrapped in carbon film.
The second would
actually be fibreglassed and skimmed in real carbon then lacquered.
This would allow me to see how it performs on the road before going to all that
effort for no reason.
So parts started arriving:
20 X M8 X 25MM cap head high tensile steel bolts with rivnuts for extra
strength.
Decided for cap heads over traditional as I feel they look nicer
With the correct washer sizes
6dm carbon wrap looks surprisingly good and matches the weave on all my
other carbon bang on.
And adjustable tie rods with real carbon covers.
Then last Saturday, we began building both splitters.
Car up in the air ready.
Scott then enlarged 4 existing holes in the chassis to make way for the rivnut
mounting points for the alloy box section frame.
I then was given the task of wire brushing the cut sections of ally that Scott
has measured to make the frame for the Splitter to mount onto.
He explained
that ally has a film on the face and will not weld correctly if this process is not
done.
Excuse the lack of photos during this stage but here the frame sits with
Scott finishing the welds.
We than bolted the 10mm sheet to the car and POW she's done.
Only joking
( Obviously
) it was now turn to decide the shape, I want functional
downforce, however road usability, and any longer or wider then we have
decided would have ruled the latter right out.
40/50 or 60mm, we decided 50mm protrusion.
And removed after running the line of the car, but with a little maths worked
out how the sides would smooth back into the shape of the bumper.
Then cut
the shape and prepped the sides with an orbital to round of the face's and
get rid of any splinters.
Next we had to cut out the rear of the splitter to allow air to flow up to the
Mishimoto rad
+ spal fans, we traced the shape and cut out and again
smoothed of with an orbital.
Then became the job of getting the remainder of the rivnut holes drilled onto
the ally frame ready for the splitter to be mounted in place.
And here is the 10mm mounted,
We then used this template to cut out and make an exact replica with the
5.5mm sheet.
Then finally for this stage it was time to fit the tie rods, simple
enough in theory to fit.
But patience and perfection is needed to get them
straight and in place.
Thats it for now, reason being is that the car was dropped back to DPM on
Monday to repair and re-paint the front bumper as some stress cracks had
appeared
( Dave said this would happen potentially after fitting and is being
done FOC of course
) So having the splitter removed allows easier painting.
Whilst the car is at DPM, Scott and myself are going to wrap the splitter in the
carbon film, ready to fit.
Really looking forward to fitting and seeing it all finished, been wanting this
front end for a while for aesthetic and performance reasons as always
