Minor updates this week.
Some good and some, well.
business as usual.
I'm trying to keep it more frequent, to avoid having the multi-hour typing marathon when trying to catch up.
The PTSD is real!
Let's get the challenging bits out of the way first so we can end on a positive note: The Mk1.5, specifically the headlights.
I've spent some time chasing ghosts again and so far I've got nowhere really.
I did or observed the following:
* Pulled the cluster and some of the dash out, to check for loose or broken connections etc
- All looks ok, to my eye at least
* Cleaned the components
(fuses, relays and terminals) with contact cleaner, as they might have had an excess of grease in them
- No difference
* Replaced the above with known-working items
- No difference
* Tested the lights using just the flasher on the storks
- The relay clicks in he frunk but the mains don't come on.
Which is the same action as when I turn the headlight switch
* The side lights work as expected in all tests
I'm fairly sure the issue isn't in the cabin, it's in the frunk area.
I'm wondering if I've popped a fuse or relay in there that I'm not aware of?! However, in a bid to move forwards I'm now looking for a local auto electrician, which was Pete's suggestion.
I always forget that there are professionals out there who can fix these types of things, I don't need to do it all myself! Hopefully the next update will be after that process and we'll finally have some good news
It currently looking like this:
In readiness for the mapping session next month, I wanted to make sure everything ECU-related within my control was done.
The bit that had been nagging at me was whether or not the mapper would have the software to use and a data lead that could speak to the ECU.
He assured me it should be ok, but we all know I've had my share of obstacles with these cars.
To make sure I was covered I've sourced the Wolf EMS software, which was a bit of a pain but I did find, along with the legacy
.NET packages it required.
Once installed I tested it and everything ran as expected: a good start! The next step was sourcing a data lead to link a/my laptop to the v550.
It required a serial connection, which as we all know, if a bit retro now
After some research I found a serial to USB cable which was compatible with Windows 10/11 and is known to work with the Wolf ECUs.
I ordered it and this landed on our doorstep the next day:
Later that day I headed out and linked everything up for some tests.
Once I've assigned the relevant COM port to it in the software I turned the ignition and tried to connect.
This was what I saw:
followed by.
Win! So now I know the ECU works, the data lead works, I have the software working on a laptop, as well as a USB stick with the software and required
.NET packages on.
It might be OTT prep wise but I really REALLY didn't want to finally get my slot and have it wasted due to issues I could have prevented.
I'll be doing some more readiness checks on the car before it goes, as well as giving it a fresh tank of fuel on the day.
