Just some quick pics of log graphs to wet the appetite.
These are from a 10 minute run carried out this evening
(on a private road of course
Please bear in mind that this particular GUI is nowhere near finished and is just the most convenient way to display the data quickly.
There are several calibration issues between the data coming from the logs and the ECU scale that are currently being taken care of
(don't take these numbers as final kids but they are very nice relative comparions).
Anyway.
MPH
= Indicated Speed
(in MPH)
THW
= Thermistor
- Water Temperature
(in Celcius)
THA
= Thermistor
- Air Temperature
(in Celcius)
AFM
= Air Flow Meter Resistance
(higher is more flow)
RPM
= Engine RPM
TPS
= Throttle Position Sensor
TVIS
= Variable Induction Butterfly
(Open/Closed)
EFI
= Injector Bandwidth
(in mS)
IGN
= Ignition Advance
(in degrees)
MPG
= Electric Seats
(On/Off)
FFS
= Fuel Sensor
LOL
= Lubricant On Line
OMFG
= Seriously, are you not getting this yet?
Fig 1
- The larch
The larch.
The.
.larch.
Fig 2
- Pull Away from Stationary followed by hard acceleration in 3rd and 4th gear.
Note the injectors running to 100% duty cycle and the MPG dropping.
Fig 3
- A steady cruise at about 40mph
- ECU is mostly in closed loop mode.
Note the TPS and ignition advance drop as the car begins to hit a longish downhill section and it's changed to 5th and the throttle is dropped.
Fig 4
- A pull away after the car has been sat for a couple of minutes.
Note the long slow pull away in 2nd and 3rd using minimal throttle and the drop in coolant temp as airflow over the radiator begins to take effect.
Hope this is of interest and.
THIS IS NOT A SCREENSHOT OF A FINAL PRODUCT.
IT'S FOR INFO ONLY AND YES I KNOW THAT IT DOESN'T HAVE ALL THE SCALES THAT ARE NEEDED
They are coming folks
- relax yourselves
HTH
