I just like keeping things as simple as possible
Hello,
I have one of your Water injection kits and am trying to find the optimum placement of the Nozzles.![]()
Background
Application is a Toyota 3S-GTE engine(Gen 3)
4 cylinder turbocharged.
Sprint car with side mount IC
(AIT sensor located after TB)
Mid-engine car so intercooling is poor,engine currently out of car so not much additional work to add nozzles to runners.
Current WI system is not progressive.
Standalone ECU.
Options
One argument is I should use a single jet positioned at the throttle body or between IC and TB, allowing the water to cool the charge and the IAT sensor to see this.![]()
The other argument is that the water does not have time to cool the charge in this situation and the IAT sensor only shows a cooler temp because it becomes wet and therefore the sensor accuracy is no longer valid.![]()
They argue that I should use four individual jets in each of the manifold runners as the manifold was not designed to be a
wet manifold and placing in the runners ensures each cylinder receives the correct amount of water.
Please could you give me your recommendation for the nozzle placement?
Is it scientifically proven that the WI does actually cool the charge air and therefore I should place the nozzle further upstream to allow it to cool the air?![]()
Or is it more important to ensure each cylinder receives equal amounts of water by placing in the runners?
Its very difficult to find solid fact and data on this topic
Thanks very much
Dan
Dear Dan,
thanks for your inquiry.
According to a statement from the technical division:
I would recommend to inject right after the inter-cooler if he is looking for cooling.In a moderate Bar-application the water will evaporate before the IAT sensor.
So this shouldn´t cause any problems.
We usually only recommend a direct port set up if it is a high HP+boost application that is using the methanol as a fuel source and needs exact quantity's to really dial
in the fuel/timing tables.![]()
Hope that answered your question.Let me know if I can help with anything else.
Kind Regards from Hamburg/Germany
Magdalena Skawianczyk
Sales
kev8611 wrote:Yeah i was thinking that but by doing it that way the charge temps will still be high so the ecu will still pull timing resulting in..
just the same?
