Whilst on the topic of handling i don't think i'd go for coilovers again, too harsh for the road and they do really need to be set up properly.
John145 wrote:Hi guys, not sure if this has been mentioned.
Why are radial tyres better than cross ply tyres in grip? Tyre wall flex.
Cross ply tyres are extremely stiff and when cornering the load transfer effect causes a stiff wheel to rotate about its contact patch centre.When the tyres flex the load transfer effect is absorbed, the roll does not happen and the footprint is maintained.
The same would be true of low profile tyres vs larger profile tyres, to a degree.Obviously 65+ profile jepodises performance due to overheating, but you would get a lot of communication through the wheel.
HTH.
Also, forgot to mention, people were talking about getting better 1/4 mile times with bigger wheels.![]()
Makes complete sense, when you have plenty of power(which a lot of the turbo MR2s have!) its very easy to spin up the wheels from a launch.
With a bigger wheel the torque acting on the road tyre interface is reduced allowing more engine power to be used before spinning the wheels.
Marf wrote:Go to a 16x7/8 setup
