Ive done some research and I suspect issues with my installation over the pinion as the cause
1)I didnt use toyota fluid
(mainly cos I didnt realise you had to until I opened the reservior, by which point it was too late) I used halfords power steering fluid instead.
There are 3 schools of thought on this issue: That it makes no difference, that you can use peugeot 307 fluid at a quarter of the price, or use toyota fluid
(£30+ a bottle).
I dont suspect this is the cause.
2)The rack guide also sets preload.
I did not realise this when I reinstalled and just did it up
'a suitably tight amount'.
I suspect the reason for the delay is this preload.
Unfortunately to adjust this I gotta remove the rack again.
3)I slightly overfilled the reservior as I was expecting 0.5L of fluid and it only took 0.3L
4)when i went lock to lock I did not leave it at full lock for 2-3 seconds as recommended in the manual, so it might not be bled fully.
I will address these 4 issues on friday and see what the deal is.
Only then can I accuse the pinion.
