[Mk2] [Turbo] Fitting XS-Power Intercooler and GTS-Chris Shroud and Fan
Re: [Mk2] [Turbo] Fitting XS-Power Intercooler and GTS-Chris Shroud and Fan
I'm not sure what I'm running at moment as I only have the standard boost gauge so dont want top play with anything until I get a proper one - hoping tp get an Omori one and fit in stock location :-)
Hi Guys, first off.
great guide this has really helped out.
Ive got my xs power intercooler all installed but i did notice it was quite a struggle to get the pipe work in place and connected up.
The pipe work at the inlet
of the intercooler seems to be a very very tight fit.
Its right up against the firewall jammed up in there.
Is it typically a very
"snug fit"??? cheers
I wish i'd seen this before atacking my car with a hammer.
only joking but i was close.
Id like to know what the difference between the stock and xs intercooler is.
They both look the same size
(xs looks a bit smaller if anything) so just wondering what is the point?
The XS power intercooler is actually bigger and much deeper.
I've had one for 3 years and have had no problems so far.
Fitting one is a bit tricky though and the hose and clamps that came with it arn't great
- I'm not sure whether they've addressed this issue since.
anyone know if there is a power increase?
notroubleclubber wrote:anyone know if there is a power increase?
or increases from a greddy intercooler?
does anyone know what size the nuts are that hold the bottom of the intercooler to the shroud????? Thanks!
Did you have a problem lining up the top pipes from the throttle body to the outlet of the intercooler? I fitted the turbo xs one yesturday and found that the pipes did not line up at all and now i have a huge boost leak which im going to sort out today by removing it and fitting it again.
Regards
John
Regards
John
Jonnie1987 wrote:Did you have a problem lining up the top pipes from the throttle body to the outlet of the intercooler? I fitted the turbo xs one yesturday and found that the pipes did not line up at all and now i have a huge boost leak which im going to sort out today by removing it and fitting it again.
Regards
John
Yes that pipe is a bit rubbish.
just fitted mine today and had the same problem the pipe work just doesnt bend enough to line up with the throttle body and now i have a boost leak lol
](./images/smilies/eusa_wall.gif)
same here, albeit with a Berk.
I think the original poster has the same problem too, looking at the pictures.
the hose clip almost has to go at an angle to the hose to give a good seal.
it will fit properly with a good jiggling around of all the hoses.
Is it bar
& plate or tube
& fin i/c Jeff?
Jeff, food for thought here
whilst the fan shroud is very efficient at low speeds at high speed it becomes a restriction.
If the air speed
/quantity going through the intercooler is more than the fan can extract you'll get a high pressure area underneath the shroud and will prevent air flow through it and cause you to loose efficiency on your IC.
If the air speed
Builders of the the UK's first 9second MR2
- 9.722
@ 148 MPH
----- 07947883103
---- www.centurymotorsport.com
TBH Ive not delved into the efficiency of it all - just gone along with the "accepted" wisdom. As mentioned by others they seem pretty good bar the hoses are awkward to fit and the clamps are bit suspect.
Although not fitted yet I've actually bought a ST205 setup plus Ive been preoccupied with more pressing mods! LOL
Century Motorsport wrote:Jeff, food for thought here.
If the air speed/quantity going through the intercooler is more than the fan can extract you'll get a high pressure area underneath the shroud and will prevent air flow through it and cause you to loose efficiency on your IC.
This is exactly why I stuck with the stock fan, itsnt it after 30mph it becomes a disadvantage?
- IMOC Affiliated Company
The fit is a lot easier if you ditch the 2 small angled pipes in replacement for some silicone pipes.
I use SFS.ask for Lee.
Also this will reduce the rigidity of the setup so the bracket on the ic doesn't snap.
You need a 54mm-63mm right angle and a 60mm 45degree joiner.
Unless you have a toyosport kit they're 58mm.
We always go for 2mm undersized to ensure a snugg fit.
Also ditch the oversize Mikalors for correct size jubilees.
what size jubilee are u using mate got a xs cooler to fit but need all new clips what u guys using.
also great write up will be handy
Most good quality joiners are 5mm thick, so add 10mm on.
A 65-90 or there a bouts would do nicely.
And 50-70mm for the smaller ones.
