Valentino MR2 wrote:You need to connect your REM to No.1 AMP wire and I'm guessing the B+ is just a battery+ cable
so to recap you have to run 4 speaker cables going to your amp, run a remote cable to the amp and connect it to No.1 AMP wire on your stereo
Then you need power and earth to the amp, Power you can take directly from the battery and you need to earth it some where under that bonnet.
And once you wired you speakers to the amp you shoud have SOUND!!!
Valentino MR2 wrote:I agree Paul but he said he was mounting the amp under there
