[Mk2] [Turbo] world first?? my downpipe SNAPPED IN HALF!!!!
oBladeo
Re: [Mk2] [Turbo] world first?? my downpipe SNAPPED IN HALF!!!!
Post by oBladeo »
That happened to mine too :s
I patched it for a while with the exhaust back box kit and exhaust putty from a car shop for short time :D
My fault tho didn't see the engine mount bolt had dropped off
Leon.
Post by Leon. »
oBladeo wrote:That happened to mine too :s
Which dp was that?
oBladeo
Post by oBladeo »
not sure didn't have a name on it but was on the car when i got it and was attached to the blitz nur
jimGTS
Post by jimGTS »
Rory wrote:Atleast you havent got to scratch you head and fault find this problem Jim. :D
yes dude, but it would be nice in the 3 years ive had the car to get the power i deserve, lol...now this, just when i was gona get the thing mapped!
where can i take the pipe to be rewelded??? is there any specific places?? i dont no jack all about welding or how its ment to be done and what materials. price??
oBladeo
Post by oBladeo »
dude you need a stainless welder as it's allot diffrent to normal weld (that just a tip)
splashnatz
Post by splashnatz »
any place that does stainless exhausts will be able to do it Jim.
jimGTS
Post by jimGTS »
yeh, ive popped a couple of emails across to a few local companies that work with stainless steel, just hope the turbo end of the downpipe isnt to hard to get off....
sounds like a drag car at the minute, cool, but worried to give it any beans, lol.
Rogue
Post by Rogue »
We've seen exactly this failure with both C2 Power and TB supplied ExtremeBoost de-cat pipes.
Patrick
jimGTS
Post by jimGTS »
ok, ive found my old standard downpipe, with cat still inside, will try and swap it over and get this welded up....
is it just a case of bashing out the inners to remove the old cat mesh? not poisonous or irritable or anything is it? daft question i know...
3sgte
Post by 3sgte »
jim before you get too excited and take it all off
put it all back together with the exhaust back on etc .try and guess where the d/p bracket will go
then mark where the broken pipes need to be in relation to each other
would be a shame to get it welded the find the flange the exhaust bolts to is pointing out of the side of the car :clown: exaggeration ,but i hope you get my point
jimGTS
Post by jimGTS »
i did a couple of marks on the downpipe so it would fit 100% correctly when redone...
the bracket, well that snapped, so its difficult to guess on that one.
3sgte
Post by 3sgte »
jimGTS wrote:i did a couple of marks on the downpipe so it would fit 100% correctly when redone...
good lad :thumleft:
Joey
Post by Joey »
Just fit a blitz decat and be done with it, might not release quite as much power as a DP but it'll never break :)
steve b
Post by steve b »
That must be the exhaust pulling on it contributing alot for both the pipe and bracket to break.
jimGTS
Post by jimGTS »
what size are the downpipe bolts? 14mm or 12mm?
steve
Post by steve »
mine were 14mm mate
jimGTS
Post by jimGTS »
ok cool, hoping there were as my 12mm are broken....
cheers
Hellboy
Post by Hellboy »
Prob snapped due to it being lagged - Stainless steel is very brittle com paired to mild steel and does not like being wrapped.
The bracket breaking did not help and the weight of stoopid Blitz exhaust cant have helped!
Best bet for now, bash the stock cat out (don't breath it in) and fit that power difference will be negligible hence why i cant be ar$ed to buy a proper down pipe and have all the rubbish like this that goes with them.
oBladeo
Post by oBladeo »
Well ths weekend i'm off to fix a down pipe on a standard turbo so if the guy wants to take pics it's fine but i just do and never take pics till after lol
-:[KM]:-
Post by -:[KM]:- »
If you are going to get it welded, make sure it is purged with inert gas. A proper weld will not get penetration without it. It will fur up on the reverse side and not last long.
