We're not talking about driving around town here, so if you hit a rut, and it steers slightly off course on a track, it's no biggy
Some may argue that when you let go of the wheel you're
Also, would someone care to explain why it's
Sponge Bob wrote:Also, would someone care to explain why it's"bad technique"?
Aidy wrote:Sponge Bob wrote:Also, would someone care to explain why it's"bad technique"?
Cos you don't know what way the wheels are facing.
Sponge Bob wrote:I don't rely on where my hands are to know which way the wheels are facing
Sponge Bob wrote:I know from the cars movement which way the wheels are facing
Sponge Bob wrote:It's just one of those things people like to say is a bad technique because it goes against what we were supposed to learn on the"driving test".
If the book says not to do it, then it must be bad technique!!!!
eatdrinkfeck wrote:aidey, you gonna let bibbs get away with that lol!
Aidy wrote:He need to look at his face in the mirror every day.![]()
I think that is punishment enough.
Yes a lot of them do, though that still doesn't make it a good technique.Interestingly the Drift King doesn't use that technique.
Sponge Bob wrote:
That's not an explanation of why it's a bad technique..
that's merely a symptom of slipping the wheel??
I don't rely on where my hands are to know which way the wheels are facing- I know from the cars movement which way the wheels are facing, plus I know where they're facing from my direction and velocity figures when I slip the wheel, as I know where the wheels will swing to based on them!
Bender Unit wrote:
Sorry L, but if you want to drift properly(i.e not gooning out of a bend) then the only way is to let the wheel go
(initially).
It winds on the lock far quicker then you could ever do and then as it goes you can catch the wheel to control the angle and lock to manipulate the car in the bend.
When I am out drifting I will litterally clutch kick to get the car sideways and just let the wheel slide out of my hands then catch it as I see fit to change the angle.![]()
After a couple of attempts it becomes very natural knowing what direction the wheels are in.
If you try and maintain grip on the wheel you wont drift, and just end up thrashing about then probably spin.![]()
Aidy, your chatting the xxxx.
like usual.
I've tried the letting go of the wheel method when drifting.It has its place and is fine at lower speeds, not necessary at all though at higher speeds.
strange nobody has mentioned that d1 cars have an increased steering lock so there is no way you could keep hold of the wheel and go lock to lock i dont know why they have it, but they do
Bender Unit wrote:
If the car isnt set up for drifting(and TBH a Caterham wont be) then its not surprising it would spin out.
Whilst Caterhams can manage a bit of power over and go sideways coming out of a bend thats not the same as going into a bend sideways, and if you want to do that you have to let the wheel go.
sadako wrote:I gather drift cars are also often set up with very high cambers to make the wheel centre faster as well.
