gtschris.com wrote:
I am reading a great book at the moment (maximum boost by cork bell) I found a paragraph that sums it up .
What is the best compression ratio for a turbocharged engine?
There is no such thing as the best or ideal compression ratio. The simple fundaments are:
The lower the compression ratio, the easier it is to produce a lot of boost with no detonation.
The higher the compression ratio, the greater the fuel efficiently and non-boosted response.
Corky's book is a good book to have, but some of the content and ideas are quite a bit out of date (it's not a new book!). For a start, this is the man that says "Water Injection is a band aid", etc. However, there's quite a bit of content in there that at least sets one off on the right path.
gtschris.com wrote:
I am not going too disagreed with the proven facts behind squish / quench area, from what I have read 0.04 or 0.1mm is the max you want. The 3sgte has far more than this standard as you have the head gasket + deck height.
It's actually 1.0mm that they talk of being the max for squish - which just so happens to coincide with what the Rev3 runs! Nice that!!!
gtschris.com wrote:
Just out of interest do you know if the rev3 has the same deck height as a rev1/2 (I never measured it).
I don't mate, no. We didn't even measure the deck height on my engine, because in working out the CR, we used a burette to measure the volume above the piston with the piston installed in the block and at TDC. I then calculated the volume of the HG holes and the combustion chambers, so I didn't really need to know the deck height. Interesting question, though!
gtschris.com wrote:Rev3 has 1.2mm head gasket standard (0.2mm more than rev1/2) so that combined with same deck height would mean a rev3 has a larger squish volume?
I don't know in terms of squish volume (I just made sure that my squish height was right). The thing is, the combustion chambers on the Rev3 engine have a larger volume than on the Rev1/2. I think this volume and the HG thickness are the main differences, so probably deck height is the same for both engines. Does anyone have any stock REv1/2 pistons sitting about, so we can see if there's a noticeable difference between those and the Rev3 ones??
