Blokey wrote:It's very easy to lock the fronts of the SC if you go to that from driving the NA but with sticky tyres it's much improved.
This is true, it's part of the reason I wrote off my first SC, locked up and
'slid' under an artic lorry that had
(wrongly) emerged from a side lane into my path
(I was doing about 60 mph at the time and had not much space to come to a stop).
Luckily it was so low that the car got wedged under the side of the lorry on the impact bars which bent up and slowed the car down
(after crushing the bonnet into the windscreen).
Quite scary but, yeah go easy with it.
I always felt the brakes were too
'touchy' esp on gravel, and that's just driving normally.
Obviously as others have said do all the
*usual* stuff like oil/brakes/flush/getting used to it before doing bushes/pulleys.
I sort of took it for granted you'd be doing those service things anyway, the more advanced stuff is worth mentioning as not everyone does it.
I didn't touch my original SC for the record
(even kept the tear drops) but then I only had it for a few months before it got killed.
Due to the fact I then bought an NA and converted it, I knew the car inside and out
(stripped both cars, swapped trannys, looms etc) I knew it was good and replaced all the worn service parts so it wasn't long before I started to improve the handling and
superflex
(or even new OEM) bushes are going to be almost inevitable if you want it to handle/feel as good as it could be regardless of how it runs when you get it
(Unless of course it's already been done!).
Lowered suspension is a different matter, drive it for a while as stock you may like it.
I just wanted to get the roofline down a bit while stiffening up the ride a touch and I don't regret it.
I haven't done any stupid/ugly mods like mad bodykits or painted interior, i've kept it pretty much standard looking exept for debadge/stripe as the car looks at least 5 years newer without those pin stripes
(though I understand some prefer them).
Anyway, just enjoy it.
i'm sure you will decide naturally what you want to do to your own car in time but I would mostly keep it as stock looking as possibly and improve where you can
(suspension, brakes).
20 year old suspension is not going to give you the best results.
