xxxx wrote:hello andy,
I tried to place the order today but they haven't heard of that size before.
That want to know the make and model
(size) of the wastegate your trying to use.
If you let me know asap i can get it sorted for you.
Tim
xxxx
Hi Tim
Hear are the details, its the 10.2psi spring
Wastegate: Tial 46MM wastegate.
(available in polished, red, blue or violet finish.
Nickel based alloys for valve and valve housing.
Nitronic 60 stainless steel valve seat, valve bushing, and lower housing hardware.
Available spring pressures:
.4Bar
(5.8psi),
.5Bar
(7.3psi),
.6Bar
(8.7psi),
.7Bar
(10.2psi),
.8Bar
(11.6psi)
.9Bar
(13.1psi), 1.0Bar
(14.5psi), 1.1Bar
(16.0psi), 1.2Bar
(17.4psi) 1.3Bar(18.9), 1.4Bar
(20.3psi).
